noisy rear end, driving me crazy!!!
Old Dec 26, 2006
greeen01civic4d's Avatar
Angry noisy rear end, driving me crazy!!!
ok, my rear end squeaks like crazy on a bumpy road, every little bump, and its driving me nuts. for a little history, i have kyb agx struts with evotion springs, and have replaced the rear knuckle front bushings, because of the tsb. what the hell could the problem be here, ive tried everything to try and stop the problem, but nothing works, replacing the bushings worked for like 3 weeks, but squeak started again.
any ideas??
Old Dec 26, 2006
modoman's Avatar
urethane bushing? urethane squeaks unless you grease it... but you don't have to grease urethane to make it last, it just makes it stop squeaking.
Old Dec 26, 2006
fuledya's Avatar
Super Member
fuledya is an unknown quantity at this point
try trimming the dust covers, trim about 1/2 inch off the bottom, that usually does the trick.
Old Dec 26, 2006
dust covers??? on the knuckle arm?? or on teh bushing??
Old Dec 26, 2006
susuking's Avatar
susuking is on a distinguished road
i'm guessing somewhere is rubbing, check for rubbing around the wheel well. and the shocks . good luck, i use to have that prob too, but i took the whole shock out and reinstall it, and now it doesn't squeek anymore
Old Dec 26, 2006
done that 3 times, nothing works, driving me nuts, and when its raining squeak goes away... wish i could figure it out
Old Dec 27, 2006
sl33pyriceboi's Avatar
ur info says u have a 01....
make sure ur front struts are aligned correctly.....because for 01s thats what usually makes a squeeking noise (even though it might sound like its the rear)
Old Dec 31, 2006
charcoalex's Avatar
charcoalex is an unknown quantity at this point
after market parts make noise.
Old Dec 31, 2006
TemjinX2's Avatar
if you have aftermarket shocks, the part he's talking about is the part of the shock where the top the spring meets the shock and inbetween there is a black dust cover. When you go over bumps, the springs might be rubbing up against the dust cover, causing sqeaking. If this is the case, you can get some electrical tubing wrap and just wrap the top part of the springs. It solved the noise for a lot of our members. I was going to do the same when i had my tein basics installed, but the sound went away after 3wks.
Old Jan 1, 2007
tfnaaf's Avatar
BLDNPSI Mod
does it have camber kits in the back? If so it may be them squeeking.... mine do
Old Jan 1, 2007
streetglower's Avatar
when you replaced the bushings, did you put a load on the rear suspension when you tightened them?
Old Jan 1, 2007
i had a mechanic install them, and no, he didnt put a load on them when he installed them, but after it rains, the sound goes away, at least for now it has gone away, i dont know why. after i had them installed, the sound went away for like 2 weeks, but drove like 1000 miles round trip, and by the time i got back the sound was back. as far as right now, no noise.
aZnVoYCe
Dec 1, 2001 09:33 PM
supercivic01
South
Nov 30, 2001 11:27 AM
CivicHX01
Nov 29, 2001 03:48 PM
JjAnGPeETuL
Nov 8, 2001 06:37 AM
crazydragon
Nov 7, 2001 05:13 PM
