Tie Rod End question
Old Dec 15, 2006
SevenCyrus's Avatar
Se7enCyrus Racing/Motorsports
SevenCyrus will become famous soon enoughSevenCyrus will become famous soon enough
I bought a new tie rod end. When I screw it on all the way it uses all the tread on the on tie rod. On the left side, there is some tread left behind the tie rod end. So what’s the deal? Is it the wrong part and its too long? Or should i try to match it to the left and tighten it with the other screw (Part #16) behind the tie rod end. If I use it, will it not mess up the steering position (don’t know the word for it, it not alignment…but something else) If so can it be fixed?
Old Dec 15, 2006
rutscivic's Avatar
rutscivic is an unknown quantity at this point
im sure you jus screw it on to were the old one was...i think you should have marked it before removing the old one
Old Dec 15, 2006
tuningmycivic's Avatar
tuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to all
so you've done this before huh?? you took the old end off and you didn't mark or count the threads required to do so? Just put it on as close to straight (once tires are mounted). Then get an alighnment ASAP, because obviously you don't know how to do your own.
Old Dec 15, 2006
SevenCyrus's Avatar
Lol. Oh brother, okay Mr, yes sir! Again, i have changed the struts twice, anyone can do that, i just never had this prob or delt with tie rod end, never said i have done that b4.
I counted the treads based on the left one and tried to match it and guess by looking at wheel, like you said, it turned out about the same as it has been, the wheel is off a little by the right when going straight. If I get an alignment, wouldn’t I still have to move the tie rod end to fix it? I thought an alignment at a shop only regarded the wheel angle, not the steering wheel position matched with the wheels direction.
Old Dec 15, 2006
tfnaaf's Avatar
BLDNPSI Mod
You need a wheel alignment, it will also straighten the steering wheel. Alignment should be done after any and ALL suspension changes including the struts
Old Dec 15, 2006
SevenCyrus's Avatar
Word
Old Dec 15, 2006
Macko's Avatar
Macko is an unknown quantity at this point
tie rod ends are not meant to be screwed all the way in. you gotta get a alignment and see how many degrees its off. then they /you gotta loosen it until it matches the OEM specs
Old Dec 15, 2006
2002civicLX2002's Avatar
The only Wyoming Redneck on here
2002civicLX2002 will become famous soon enough2002civicLX2002 will become famous soon enough
even if you mark where the old tie rod ends were, and then put new ones on, it will never be aligned. put them on, then take it to an alignment shop.
Old Dec 16, 2006
tfnaaf's Avatar
BLDNPSI Mod
Not NEVER, i have done a few tie rods before and got lucky and didnt need to make any adjustment before
Old Dec 16, 2006
as have i, but only had to put one on the civic. damn stud snapped right off when i was changing out the oem struts for the B&Gs...now I have Blues and S-Techs
Old Dec 16, 2006
SevenCyrus's Avatar
yea i put on blues, ride is so much better now with a 2" drop, i have been riding with stock for 2 years now, lol, i think it was time for a change, i was tired of having an 2004 civic that felt like a 50 year old car.
hans.pcguy
Jul 12, 2015 12:19 PM
mrohitredd
May 28, 2015 10:03 AM
tomg
May 21, 2015 07:05 AM
pheaton
May 4, 2015 08:26 PM
El_Spic
Apr 23, 2015 03:14 PM
