Tein S. Tech springs question
Old Dec 13, 2006
ultimatetuner10's Avatar
Technical Assistant
ultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond repute
Are these for the coupe AND sedan? All of the sites dont really say anything different about them, but just wanted to make sure before i buy
Old Dec 13, 2006
2k2civicsedan's Avatar
2k2civicsedan is an unknown quantity at this point
I just got the S. techs for my sedan. The guy told me there wasn't a difference. They fit on my car. But you DO NEED a camber kit. My rear camber was really bad. The front wasn't as bad but you need a complete kit.
Old Dec 14, 2006
Technical Assistant
no ****ing way thats another 200...doesnt an alignment usually take care of that
Old Dec 14, 2006
If you want to keep your tires then you will get a camber kit. If you do not want to get a camber kit then get the H-techs or the Eibach pro kit. Anything over a 1.25" drop needs a camber kit. If you do not get a camber kit then your tires will only last about 2500 or 3000 miles. After you get the camber kit then you can get it aligned.
Old Dec 14, 2006
slowwhitecivic's Avatar
slowwhitecivic will become famous soon enough
i got camber wit Eibach pro kit on my sedan. so its best to get camber kit regardless
Old Dec 14, 2006
spoonEM's Avatar
omgwtfbbq mod.
The S tech springs are for the coupe. The sedan obviously has a heavier *** end and the s techs werent designed to handle it. Sure, theyll work, but theyre going to sag like crazy. I had them on my coupe and I didnt like how much lower the rear was than the front, and once they settle, its going to be worse on your sedan.
Old Dec 14, 2006
bobsagator's Avatar
bobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of light
ditto!
Old Dec 14, 2006
gaugeof12's Avatar
gaugeof12 has a spectacular aura aboutgaugeof12 has a spectacular aura about
^This is correct. I would not put them on a sedan, unless you are a fan of the *** sag. LOL
Old Dec 15, 2006
smk's Avatar
smk
smk is an unknown quantity at this point
I have Neuspeed Sports that were made for sedan on my coupe. No *** saggage for me! Although I do wish to make my car a little lower... maybe a set of coilover will fix this.
Old Dec 15, 2006
TheGeneralLee's Avatar
TheGeneralLee can only hope to improve
actually they arent that bad, i got my s techs from spoonEM(robbie) its true the sedan is alot heavier but they will eventually settle in. the stechs are just something to lower the car for now but i will eventually go back to the SS coils again. BTW thanks for letting me know that robbie when you gave them to me!
Old Dec 15, 2006
Old Dec 15, 2006
spoonEM's Avatar
omgwtfbbq mod.
you asked for them. you said you didnt want your car sitting at ride height. and actually, I did tell you they were for a coupe and not a sedan and that it was going to sit lower in the back. I guess you didnt hear me. besides, even if you did hear, you still wouldve had me put them on.
Old Dec 15, 2006
CenZ's Avatar
PWIT
of course it wont sag in the back for you. you got springs that were rated for a heavier rear end on your light rear end, your car just want drop as low in the back.
Old Dec 15, 2006
TRIZ's Avatar
as far as camber kits go- you dont exactly need one- if you can get everything dialed out with the stuff thats on your car already then more power to your mechanic. But he probably wont be able to after a certain point so bamb, thats when you need a camber kit.
Man.. wasnt there a sticky on "DO I NEED A CAMBER KIT?" in the suspension forum?
Old Dec 15, 2006
EXsmellsbetter's Avatar
Mr. Treehorn treats objects like women, man!
EXsmellsbetter has a spectacular aura aboutEXsmellsbetter has a spectacular aura aboutEXsmellsbetter has a spectacular aura about
No that's wrong. I put my s-techs on around 10k miles ago and my tires are all holding up like ****ing champs. Hell no I wasn't going to buy a camber kit. Just make sure to keep rotating your tires and you'll be good.
GolNat
Nov 27, 2018 03:32 PM
TheRiddicles
Sep 21, 2015 03:43 PM
TheRiddicles
Sep 21, 2015 01:28 AM
cukaracha
Aug 29, 2015 05:27 PM
EM_WON
Jul 22, 2015 06:49 PM
