jacking point after installing nuespeed rear tie bar
Old Nov 28, 2006
fuledya's Avatar
Super Member
fuledya is an unknown quantity at this point
I am getting ready to install my nuespeed rear tie bar, however I am noticing I won't be able to jack my car up in the middle anymore. Has anyone found a way around this? I always liked being able to jack the rear up using the middle frame point below the rear sway bar.
Old Nov 28, 2006
eh.. i just put the jack under the newspeed rear tie bar.. lol.. i've had no problems doing so..
Old Nov 28, 2006
ian01ex's Avatar
ian01ex is an unknown quantity at this point
Did either of you have any problems loosing that little thread nut that you put in the 1/2" drilled hole. I had one go in fine and the second one pushes through so you cant thread anything into it. I was just gonna cut the old one off and buy another tool and thread bolt unless you guys have any suggestions. I also thought about heating it up to make it expand and possibly having it stop moving around if its hot?
Old Nov 28, 2006
burke420's Avatar
The World Is Yours!
i dont have the nuespeed, but i got the Progress rear combo meal, and they work deliciously with a jack, just dont rush yo'self to get it up! it did fine. but let the jack compress before yanking it out. i hit my bar once, never again!...lat'r
Old Nov 28, 2006
fuledya's Avatar
Super Member
i don't really like the idea of lifting the car up by the tie bar...
Old Nov 28, 2006
robbclark1's Avatar
Retired suspension supermod.
then deal with it! haha
The neuspeed and progress bars can probably handle it, but I wouldn't do it.
Old Nov 28, 2006
DDragon7's Avatar
Jack the tow hook instead.
Old Nov 28, 2006
fuledya's Avatar
Super Member
is it strong enough? My lip kit might be in the way (Kaminari).
Old Nov 29, 2006
robbclark1's Avatar
You can use the tow hook but make sure you jack can go high enough...mine can't.
Old Nov 30, 2006
ren808's Avatar
ren808 is on a distinguished road
use the tow hook...this works best when your dropped too
BootyDo
May 7, 2015 04:46 PM
Dorval Andre
May 1, 2015 09:37 AM
edgenet
Apr 28, 2015 07:49 PM
BiGbRoWn
Bolt-on Engine Performance
Nov 21, 2001 06:17 PM
CapYoda
Nov 11, 2001 05:17 PM
