stripped bolt
Old Nov 8, 2006
greeen01civic4d's Avatar
stripped bolt
i have a pretty serious problem, first, im getting the popping sound from a bad install, my fault, and to further this problem, my idiot self used a 9/16ths wrench on the upper bolt, and rounded it, and cannot remove it to fix the popping sound, what the hell can i do to get the bolt off of the top of the strut(rear btw) since its rounded and all???? i thought about using an impact, but sadly dont have one, but using a socket wont work, because you have to use an allen wrench as most of u know, what the hell do i do??????
Old Nov 8, 2006
manahoonie's Avatar
they sell sockets that get stripped bolts off (same concept as the screwdriver bits that get stripped phillip-head screws out)
i'd say to head down to ACE and/or OSH tomorrow
if ypu want a pic to show them what the socket looks like, i can have one for you tomorrow afternoon...
Old Nov 8, 2006
socket wont work, i have one of those, but when you turn the bolt, you have to use an allen wrench at the same time to hold the strut in place while you remove the bolt, i already tried it that, thanks tho....
Old Nov 8, 2006
manahoonie's Avatar
hmm.. guess i misunderstood the first post. oh well...
still don't know why you need an allen wrench to hold it in place....
how about filing down two sides of the bolt, then using a monkey wrench?
Old Nov 8, 2006
manahoonie's Avatar
and/or vise-grips...
Old Nov 9, 2006
04civic07's Avatar
Living Life Turn After Turn
04civic07 will become famous soon enough04civic07 will become famous soon enough
yeah.... vice grips ^ like he said
Old Nov 13, 2006
D17master081's Avatar
D17master081 is an unknown quantity at this point
get a nut splitter...and split that bad boy in half i had the same prob wit my tie rod end nut....so i just got a nut splitter and shazam!!!! worked like a charm
Old Nov 13, 2006
Civicman1988's Avatar
i used vice grips when i had the problem or an impact i round a bolt and the impact took it right off.
Old Nov 14, 2006
zps2004's Avatar
zps2004 is an unknown quantity at this point
at lowes they sell a socket set that is open so you can use a rachet and the allen to keep it from moving.
Old Nov 14, 2006
PunkingCivic's Avatar
I need TP for my bunghole
NUT SPLITTER AT SEARS
OR
VISE GRIPS
Old Nov 14, 2006
familycar's Avatar
http://www.sears.com/sr/javasr/produ...id=00952166000
craftsman bolt out kit. it has a open center so you can use the allan at the same time. use a deep socket to hammer it on then turn it out with a wrench around the bolt out nut. its easy. i had to remove some lug nuts with some of these because i didnt recieve the lug key when i bought a car
Tedverseti
Sep 29, 2015 05:41 PM
rovafa2002
Sep 28, 2015 06:57 PM
2002ExCivic
22
Sep 28, 2015 08:29 AM
pilebuck13
Sep 21, 2015 10:45 PM
amrhamed
Sep 21, 2015 02:56 PM
