Replacing tie rod end
Old Oct 22, 2006
Coloraduh_Civic's Avatar
Coloraduh_Civic is an unknown quantity at this point
I did a search and found this diagram.
http://www.hondaautomotiveparts.com/...=P.S.+GEAR+BOX
It looks like I need parts 7,23,24. When installing the tie rod end, how tight should it be on the tie rod? And I know I got to get an allignment after its installed. Thanks
Old Oct 22, 2006
robbclark1's Avatar
Retired suspension supermod.
Yes you need 7, 23, and 24.
1) Unscrew nut that holds tie rod end onto tie rod
2) Pull out cotter pin on tie rod end
3) Unscrew tie rod end nut
4) Loosen tie rod end from steering arm
5) Screw tie rod end off
6) Reverse process
The nut that holds the tie rod end onto the tie rod should be has tight as you can get it. Tighten that after the tie rod end is back into the steering arm and somewhat tightened down to the steering arm.
Old Oct 22, 2006
Thank you
+1 rep
Old Oct 22, 2006
robbclark1's Avatar
Thank you
+1 rep
The tech will loosen and tighten the nut when he/she does the alignment. Just make sure it is tight when you are done. It is unlikely that your alignment will change that much even if the nut is loose in between the time you are done and the time you get an alignment, unless you wait over a week...i.e. don't be lazy and get your *** to an alignment rack
Old Oct 22, 2006
Why not keep the bad camber and wear out my tread while I wait for an alignment lol.
Old Oct 22, 2006
robbclark1's Avatar
Tie rods change toe, not camber If you want new tires, feel free
Old Oct 22, 2006
Ha Ha I knew that So my totall for parts 7,23,24 came out to 53.00. I guess thats not to bad. I wish I wouldnt of messed up the TR end in the first place. O well live in learn.
bravo79
Suspension
18
Feb 10, 2022 09:52 PM
pheaton
May 4, 2015 08:26 PM
El_Spic
Apr 23, 2015 03:14 PM
thesushiboy
Apr 12, 2015 02:54 AM
bluecoupe
Dec 20, 2001 07:12 PM
