Swap, changes on handling....
Old Sep 9, 2006
kornsined's Avatar
Now that i have my swap done i'm kinda wondering how it has affected the way the car handles. The engine has obviously added weight to the front end. From my experience with the car the characteristics seem to be the same but it's hard for me to judge since I didn't drive the car for half a year. I'm still using the 15mm front and 19mm rear sway bar setup.
Basically what I'm wondering is:
How does added weight in the front affect handling?
Is it similiar to an rsx?
Old Sep 9, 2006
Boilermaker1's Avatar
Jap-Euro Fusion
Its 70 lbs out of nearly 2900. You can bump the spring rates up 25 lbs if you feel like it, but the new motor is not going to make a difference. The weight distribution is much better in the coupe/sedan vs the RSX anyways (its 59/41 vs 70/30) because of the long rear overhang and the junk they put back there.
Old Sep 9, 2006
Kevbotron's Avatar
I like my commute
Very interesting, civics have a better weight distribution than an RSX.
Old Sep 10, 2006
kornsined's Avatar
i thought there wasn't any drastic changes but since it was a long time since i drove it i wasn't sure.
Old Nov 6, 2006
kornsined's Avatar
thought crossed my mind......with the greddy intercooler the front rebar was removed. It was reinforced but not anywhere near stock. Does this effect handling and chassis flex?
Old Nov 6, 2006
Nameless's Avatar
TURTLEonK
Nameless is a jewel in the roughNameless is a jewel in the roughNameless is a jewel in the roughNameless is a jewel in the rough
^ I dont think enough for you to really feel the difference.. especially since its all the way up front..
Old Nov 7, 2006
kornsined's Avatar
ok,thanks. although safety is another issue . at least mine is somewhat reinforced.
Old Nov 7, 2006
EMK20a2's Avatar
EMK20a2 will become famous soon enoughEMK20a2 will become famous soon enough
I autox mine and had it setup neutral to maybe a bit of oversteer before. The swap does make the back end feel a bit lighter and add to the oversteer somewhat. I had to raise my coilovers to compensate for the added weight, but I think new springs and different shocks may be in order.
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
Scout1
Oct 5, 2015 01:33 PM
juicetayne
Sep 30, 2015 11:02 AM
ThatGuy913
Sep 28, 2015 05:35 PM
ttamrekab
Sep 28, 2015 01:22 AM
