What parts for replacing tie rod ends?
can anyone tell me exactly what parts they will need to replace the tie rod ends? I was going to buy online and have them install it. Anyone kno what parts exactly for the front tie rod ends, thanks!
http://www.hondaautomotiveparts.com/...=P.S.+GEAR+BOX
Is it 7, 8, 23, 24? TIA Also if its 24, is it 2x25 or 2x35 since theres two 24 listed on there site.
At the very minimum, you will need 7,8 and 24 (the 2x35 will be fine, it's jost a cotter pin, and it won't hurt being a little longer than needed). 23 and 16 should be reusable, but if you want, you can get those too.
all you need is a tie rod assembly, napa or autozone should have them not to expensive either, like 50 bucks each, and make sure to do an alignment afterwords also otherwise your toe will be out way bad.
thesushiboy
Apr 12, 2015 02:54 AM
my2k1vic
Nov 29, 2001 10:29 PM
