Help Replacing Struts??
Old Aug 13, 2006
drixx12c's Avatar
drixx12c is an unknown quantity at this point
I've read the DIY on replacing OEM springs with aftermarket that helped me in taking out my old struts, but i have 2 small questions for u. 1) I'm goin to use diy to change my 02 coupe EX struts to KYB GR-2 or Monroe Sensa-Trac , which one should i use between the two? and which ever one u recommend, how do i install it, are they just inserts or do they come with that part that connects to the tie rod? if they dont come with the part that connects to the tie rod, how do i replace the original insert with the new one??
2) And after installing these struts, i have a upper strut bar that i want to use but when placed in position, it blocks my engines air filter when i want to replace it, or can the long bar be removed easily by the bolts on the ends whenever i want to clean my filter???
GH04si
Apr 15, 2015 08:13 PM
thesushiboy
Apr 12, 2015 02:54 AM
deception420
Dec 6, 2001 02:31 PM
