Skunk2 Question, NO HATERS ONLY HELPERS!
Old Jul 19, 2006
lexicon's Avatar
New Member
lexicon is an unknown quantity at this point
My shop is putting on Skunk2 coilovers on my 01 EX....problem, he is stating that is looks like a drag car. He says the rear is lowered as far as it goes and there is still wheel gap!!!??? WTF??? Has anyone else experienced this? Any suggestions as to what needs to be done? And please no haters saying Skunk2 sucks, buy gc or yadda yadda. This is what I have, and this is my problem w/ installing them. please help! thanx
Old Jul 19, 2006
fallout's Avatar
fallout is a jewel in the roughfallout is a jewel in the roughfallout is a jewel in the roughfallout is a jewel in the rough
Ride heights almost never go as low as advertised. I have Progress coilvers, which is advertised to go as low as 4 inches, but in reality, i can't get it to go lower than 2" at its max.
The guy at the shop is probably an idiot because the springs also need time to settle. You can't expect it to go all the way down after installation. Take your car out to the freeway and beat it hard. It'll be lower after about 100 miles or so.
Old Jul 19, 2006
Gixxer's Avatar
Hey, I know Drew22Mader, the man with the sickest whip
Gixxer is a name known to allGixxer is a name known to allGixxer is a name known to allGixxer is a name known to allGixxer is a name known to allGixxer is a name known to allGixxer is a name known to all
Check to see if he cut the bump stops or not, That may be keeping it from going any lower.
Old Jul 20, 2006
lexicon's Avatar
New Member
I asked him if he cut the perches and he said yes, in the front. is there also cutting that needs to happen in the rear? thanx for all the help guys
Old Jul 20, 2006
HondaKorn's Avatar
Life is better with 5lug
shorter springs maybe??? I think the shorter springs go on the rear....
Old Jul 20, 2006
CenZ's Avatar
PWIT
well you really cant mess it up. the rear springs are thin, the fronts are wide
you can fit the rear springs inside of the front springs. cause thats how my OEM ones are right now.
Old Jul 20, 2006
lexicon's Avatar
New Member
he said the directions that came with the coilovers said to place the smaller ones in the front and the bigger in the rear....he thought that was backwards but it's what they called for he said....so it should be the bigger in the front and small in the rear, correct? that just makes more sense cuz the there is more weight in the front so it would need the bigger
Old Jul 20, 2006
Gixxer's Avatar
These are sleeve coilovers correct? And they are going over stock struts? In the front he should have cut the base that the stock springs sit on along with the rubber stop marked in green.
On the rear all You should have to do is cut the rubber stop. Also marked in green.
Old Jul 20, 2006
lexicon's Avatar
New Member
figured it out, the dumba$$ had the front so low the it was kickin the back end up....it's all good now, but thanks everyone for all the great help!!!!
Old Jul 20, 2006
soldierboi's Avatar
soldierboi will become famous soon enoughsoldierboi will become famous soon enough
lol his a dumbass lol well glad to hear that ts fixed now
I was gonna suggest to pick up like 2 or 3 fat *** chicks and take em for a ride ..maybe ill will help make it settle faster
Old Jul 20, 2006
robbclark1's Avatar
Retired suspension supermod.
Uh, he probably had to drive it and let the rear springs settle down. The fronts settle faster because of the engine weight.
Old Jul 20, 2006
burke420's Avatar
The World Is Yours!
mine have a lil bit of a drag look too, but i mean the springs seem to play all the part. GC would work best. but i love my ride for now, one-day maybe some TEIN SS-p
junkyardguy
Sep 2, 2015 06:07 PM
naokigoffi
Aug 30, 2015 06:19 PM
S1N7H3T1C
Aug 28, 2015 01:00 PM
S1N7H3T1C
Jul 21, 2015 05:20 AM
Theshwartz35
Jul 17, 2015 11:13 PM
