Tein and Tie rod problem, Urgent
Old Jun 6, 2006
ashtonp's Avatar
ashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to behold
Alright, I just ran into a huge problem.
I have Tein SS on my car which was making popping noises on the passenger front side for quite a while. My buddy and I tried everything to get rid of it but it wouldn't go away. I took it in to Crown alignment today, and they said the tie rod nut came loose and fell off, damaging the taper on the tein shock that connects it to the tie rod end. They're working on it right now but is there anything I can do about this if they can't fix it? I got the Teins at Phantom (the guys who worked on Acurabot). Any help is good help right now, this is frustrating as hell.
Thanks Guys
Old Jun 6, 2006
KINGCHILE's Avatar
KINGCHILE is a name known to allKINGCHILE is a name known to allKINGCHILE is a name known to allKINGCHILE is a name known to allKINGCHILE is a name known to allKINGCHILE is a name known to allKINGCHILE is a name known to allKINGCHILE is a name known to all
who installed them?
Old Jun 6, 2006
ashtonp's Avatar
Me+Friends
Old Jun 6, 2006
KINGCHILE's Avatar
your sol man, if you would of had a authorized installer do it they would have replaced it. but your warrenty is voided if you do it.
Old Jun 6, 2006
TransformedBG's Avatar
I Hunt Goats, Rams, And Mustangs.
TransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of light
YOu could always go ghetto and try and shim it up.
Old Jun 6, 2006
ashtonp's Avatar
Anyone know of any tie rod flip kits for civics?
Old Jun 8, 2006
ashtonp's Avatar
Update: The tie rod was secured properly, but the car was still making a little bit of noise after the alignment. I took her in to honda to make sure it wasnt sumthing other than suspension making noise and the tech said the springs on the teins werent tight enough, thus turning while I turned the steering wheel and making noise. Any suggestions? the teins have 6 threads left, the car has no wheel gap, I dont understand how the springs arent tight enough. I don't know what to do, any help is appreciated.Thanks.
bravo79
Suspension
18
Feb 10, 2022 09:52 PM
mrohitredd
May 28, 2015 10:03 AM
tomg
May 21, 2015 07:05 AM
pheaton
May 4, 2015 08:26 PM
El_Spic
Apr 23, 2015 03:14 PM
