RSX-Civic Sway Bar Swap
Old May 23, 2006
CivicRunner22's Avatar
CivicRunner22 is an unknown quantity at this point
So my mom drives a base model rsx, i was planning on stealing her 19mm rear sway bar to put on my 02. i know i need to use the 19mm bushings with the rsx bar on the civic, i am assuming i would be able to put the civics sway bar(i believe is a 12mm) on her car with 12mm bushings without a problem. Right? this wont cause a major difference on the rsx for a 50 year old mother would it? she takes corners like an old lady so i figured she wouldnt miss it. I just want to make sure my civic sway bar will fit on her car before going through the work. Thanks
Old May 23, 2006
half_n_half17's Avatar
half_n_half17 is an unknown quantity at this point
Sure and while you're at it you should check her purse for loose 20's
Old May 24, 2006
invrtdsa1nt's Avatar
invrtdsa1nt has a little shameless behaviour in the past
hey dude, why dont you just give it a shot and tell us. im interested in this, and well, you have access to do it. so do a little experimenting. its not like anything could go wrong, right? besides, half the time i take advice from other people here it ends up being wrong.
Old May 27, 2006
TeLLy's Avatar
Yes, it's an Acura EL
Why don't you just go buy your own? Less than $70 all told if you get a used bar and bushings. Just make sure your mom is cool with it, worst case scenario is if she gets in an accident and insurance sees there's been an alteration in the suspension, they might not fix it for her. If she corners like a gramma I don't see her missing the bar that much and your stocker should fit just fine.
Old May 27, 2006
jester444's Avatar
Dain Bramaged.
jester444 is an unknown quantity at this point
I don't think he meant "stealing" in the literal sense. I highly doubt he could "steal" suspension parts off of her car without her noticing. Correct me if I'm wrong, but I'm thinking he's just gonna swap them, with approval.
Old May 27, 2006
TeLLy's Avatar
My bad, a little cranky this morning. Edited.
Old May 27, 2006
Xenin's Avatar
Superior Evolutionary Element Destined-factor
Xenin is an unknown quantity at this point
base model RSX doesnt have a 19mm bar, more like 17-18mm.
Old May 27, 2006
ajhdragon's Avatar
7thgens official a$$hole
the RSX has a SWay bar that size for a reason. leave it that way and just buy one.
pizzahutcombo
Suspension
Jul 13, 2021 09:41 PM
juror
Suspension DIY
Jul 30, 2019 03:28 AM
Marco83
Oct 13, 2018 10:13 PM
muniorbust
33
Aug 31, 2015 08:59 PM
protoCall7
Bolt-on Engine Performance
Jul 26, 2015 07:41 PM
