Noisy Suspension HELP
Old May 8, 2006
AntiLoop's Avatar
AntiLoop will become famous soon enough
Question Noisy Suspension HELP
Setup - 2001 civic sedan lx
- Tokico Struts and lowering springs
My suspension makes a clunk/pop sound usually when I make a left hand turn and go over a small bump.
The sound comes from my Front Passenger side Wheel.
MY springs also tend to make sounds when I just turn my wheel left and right sounds like the spring is adjusting?
Any help would be much appreciated. Even better if someone can fix my problem, I am willing to Pay to get it fixed.
Thanks ahead of time
Old May 14, 2006
Nameless's Avatar
TURTLEonK
Nameless is a jewel in the roughNameless is a jewel in the roughNameless is a jewel in the roughNameless is a jewel in the rough
you didnt index the strut mount properly when reinstalling.. you gotta do it again
Old May 14, 2006
Sam18
Guest
Posts: n/a
Would this have caused damage to his car already?
Old May 14, 2006
01vic's Avatar
ultra super duper member
01vic will become famous soon enough01vic will become famous soon enough
i told him this a million times and he wont listen....
dude, just take it back to where you had it done and tell them to properly index the mount.... or if you did it yourself FIX IT!!!!!
nope
Old May 14, 2006
mr_fobster's Avatar
yea i had the exact same problem, but all i did was just realign the arrows on the top mount and it all went away.....
Old May 15, 2006
AntiLoop's Avatar
I did go back already he already had them indexed correctly he showed me it. But he tried correcting it again. sound has gone away a little bit, but still slightly there when i make left hand turns and hit bumps still.
Old May 15, 2006
ashtonp's Avatar
ashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to behold
it sounds to me like the spring is not spinning properly when making turns and is thus jumping and making those noises. take out ur top mount bearing, take it apart and grease it up and put it back together. this will allow it to spin better and the noise should go away for good.
Old May 16, 2006
invrtdsa1nt's Avatar
invrtdsa1nt has a little shameless behaviour in the past
mine did this forever. i keep hearing people say its that its not indexed correctly which is wrong. i had mine indexed correctly because i have the L and the R on my upper mounts. so i know i did it right. and it doesnt match up unless you do it this way. but i left out those round things that go right under the uppermounts that have all the ball bearings in them. i put those in, and now i dont get the clicking noise. the end.
Old May 20, 2006
InanimateCarbonRod's Avatar
InanimateCarbonRod will become famous soon enoughInanimateCarbonRod will become famous soon enough
Did you (or the installer) put the black rubber like jacket on the bottom end of the spring? My car was making the same noises over small bumps and it drove me nuts. I reinstalled the springs with the rubber jackets and the noise went away.
Old May 20, 2006
tuningmycivic's Avatar
tuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to all
so u left out the strut bearings and was wondering why it was noisy?
Old May 23, 2006
AntiLoop's Avatar
What did you leave out exactly? And can that be realyl safe ?
Tedverseti
Apr 23, 2020 01:45 PM
Scout1
Oct 5, 2015 01:33 PM
Tedverseti
Sep 29, 2015 05:41 PM
speedlever
Sep 24, 2015 07:18 PM
czarlun
Sep 14, 2015 08:16 PM
