Air ride on ebay..is it legit?
Old Apr 11, 2006
AllEyezOnMe's Avatar
[]D [] []\/[] []D
AllEyezOnMe should not be trustedAllEyezOnMe should not be trusted
Arrow Air ride on ebay..is it legit?
http://cgi.ebay.ca/ws/eBayISAPI.dll?...%3ACA%3A1&rd=1
Lookin at this air ride kit..which im a noob at..is this a proper kit? says its off an 02 civic..is this straight bolt on?..thnx
ME:
Hey i have a 2002 civic lx 2 dr..does everything work? Also, is this a bolt-on for the 02 civic or will it require fabrication?
SELLER:
was working when it was removed from vehicle. I think it is a bolt on. it replaces struts in the front and shocks in the back/
Old Apr 11, 2006
RHCP0801's Avatar
well i wouldnt buy it cause his feedback, hes only sold 3 items and 1 was a negative feedback and the price is very very cheap....i wouldnt do it if i were you
Old Apr 11, 2006
djrabbi's Avatar
djrabbi is a name known to alldjrabbi is a name known to alldjrabbi is a name known to alldjrabbi is a name known to alldjrabbi is a name known to alldjrabbi is a name known to alldjrabbi is a name known to all
i wouldnt either...... its ebay man, ebay is good for small stuff
Old Apr 11, 2006
[]D [] []\/[] []D
But as far as product...is it all there..for a complete set up?
Old Apr 11, 2006
LowLife's Avatar
LowLife is a name known to allLowLife is a name known to allLowLife is a name known to allLowLife is a name known to allLowLife is a name known to allLowLife is a name known to allLowLife is a name known to allLowLife is a name known to allLowLife is a name known to all
From what I can see, it comes with pretty much everything you would need for a basic setup... front/back, no side/side. can't tell what brand the valves are... the compressors are not 100% duty cycle which I am not a fan of. Doesn't come with any relays for the compressors or pressure switch's or water traps, no gauges.... although the price would be worth it for the compressors and tank alone
Old Apr 11, 2006
[]D [] []\/[] []D
Thanks Bro...I will pass then! Seems like it would be more of a hassel..ill just get it done right
Old Apr 12, 2006
LowLife's Avatar
no prob man
Old Apr 13, 2006
YSIDRAG's Avatar
YSIDRAG is an unknown quantity at this point
This is all true but it does have side to side. It has a 10 switch set up so it would have f/b/, s/s, pan cake, seesaw, and a switch for each wheel. It is missing a lot of the small things you would need. For that price well worth it. But it is ebay.
-Jay
Old Apr 16, 2006
yngad's Avatar
yngad is an unknown quantity at this point
ask if he'll gaurantee that it won't arrive DOA
Old Apr 17, 2006
LowLife's Avatar
-Jay
Nice try but... no. The amount of switches in the switch box does not define how many actions the setup will give you. In all actuality you could run f/b/s/s on just 4 switches. What gives you the ability to hit sides and idividual wheels is the # of valves you're running.
4 valves = your basic f/b setup - 2 valves (1 lift and 1 dump) in front, 2 valves (again, 1 lift and 1 dump) in the rear.
8 valves = f/b/s/s - 4 valves (1 lift and 1 dump for each wheel) in front, 4 valves (again 1 lift and 1 dump for each wheel) in the rear.
More in detail - on a f/b setup the 2 front wheels would be tied together using 1 lift and dump valve. When you hit the switch to raise it, the lift valve would open sending the air through a T-fitting to both wheels at once. The same would happen when hitting the dump. On a f/b/s/s setup what ties the wheels together is the wiring on the switch box, that is all. When you hit "front up" the box opens both valves (one for either wheel) at the same time lifting the front end. You could also hit both wheels individually to get the same effect, which is not possible on a 4 valve setup.
Bounddyy
Jul 8, 2015 11:22 AM
Youshoe
Air Conditioning
Jul 8, 2015 09:49 AM
7thgensurvivor
Jul 5, 2015 12:17 PM
Causemo
Jul 4, 2015 07:11 AM
