tein clunking fix?
Old Mar 15, 2006
Boost_Junkie's Avatar
Boost_Junkie has a spectacular aura aboutBoost_Junkie has a spectacular aura aboutBoost_Junkie has a spectacular aura about
tein clunking fix?
i know the option would have been to get 01 mounts or the pillowball mounts but meh...i was thinking about just greasing up the whole thing?
makes more noise in rain/cold than warm weather..
anyone have solutions?
Old Mar 16, 2006
ashtonp's Avatar
ashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to behold
i have 01 mounts on my tein ss and it was clunking for a while. the problem was the top mount bearing wasn't spinning when the car was turning so the springs were jumping and making noise. i greased up the bearings and the noise went away for a while, then came back in small intervals but then went away completely. try it out, should do the trick
btw do u not have 01 mounts??
Old Mar 16, 2006
no i used my stockers (05) mounts, what kind of greaser did you use?
how did you get in there? i dont wanna have to take it out to do it
Old Mar 16, 2006
ashtonp's Avatar
i used rust check greaser but wd40 will do. i would HIGHLY recommend you use 01 mounts tho.
Old Mar 16, 2006
ragingSPAM's Avatar
I just burnt my tongue
with the 01 mounts you have to index the top mounts right...if you dont put it together right it'll clunk no matter what you do...its the same with lowering springs and whatnot on oem or aftermarket shocks
Old Mar 16, 2006
ashtonp's Avatar
oh ya the way i did it was i took the strut assembly apart to grease it. You have to remember, your life is riding on your suspension, so do it right no matter what.
Old Mar 16, 2006
its done right, but the teins notoriously clunk...imma grease it up big time...
Old Mar 16, 2006
MajinB's Avatar
Drunken Master-7thgen Ninja
its not grease. its the indexing
Old Mar 16, 2006
03-Acura-1.7-EL's Avatar
03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light
Exactly.
Springs do not make noise.
Improper strut assebly does.
Stick at top of the forum will tell you how to get rid of the noice property, should I say not to have it it in the first place.
Old Mar 17, 2006
we did mark the assembly before take it apart...so i know its not improper install...
bravo79
Suspension
18
Feb 10, 2022 09:52 PM
Dorval Andre
15
Jul 1, 2015 09:32 AM
cukaracha
Jun 7, 2015 03:32 PM
elitezdc5
May 26, 2015 05:46 PM
