my rear is one side higher than the other?!
Old Mar 14, 2006
jdm_veloz's Avatar
jdm_veloz is an unknown quantity at this point
i looked at my car today and found out that my rear is one side sitting higher dan the other. one side is 2 finger gap, n other is like 1/2finger gap. i dropped on tein, with agx for about 2months now. could harsh turning be the reason? or will it go away after a while. what should i do?
Old Mar 14, 2006
import2nr's Avatar
awd pwnz j00
Anything inside the trunk on one side, like a system?
Old Mar 15, 2006
jdm_veloz's Avatar
nope nothing.
Old Mar 15, 2006
HonCivX02's Avatar
HonCivX02 is an unknown quantity at this point
if you have the same components on both side and if you are parked on a 100% flat area and one side is lower then take it back to where you got it put on at. Something is messed up.
Old Mar 15, 2006
Boilermaker1's Avatar
Jap-Euro Fusion
Its known that the left side sits lower than the right.
Weight dist. of the car, everything is on the left.
If the difference is large, look for blown shocks.
Old Mar 15, 2006
SleakCivic02's Avatar
SleakCivic02 should not be trustedSleakCivic02 should not be trusted
WHAT SPRINGS YOU GOT, IF YOU GOT LIKE AEROSPEEDS OR DROPE ZONE, THEN ITS THE SPRINGS. i THOUGHT YOUR SPRINGS SET THE HIGHT OF THE CAR NOT THE SHOCKS, I COULD BE WRONG
Old Mar 15, 2006
sl0wEM2's Avatar
GO LOW or GO HOME
sl0wEM2 has a spectacular aura aboutsl0wEM2 has a spectacular aura about
Blown shock or bad installation.
Old Mar 16, 2006
jdm_veloz's Avatar
your right, my left is the one sittin lower dan the right, but not a bit difference, but enough so u can tell dat it is lower. soo your saying that this is normal on a civic?
Old Mar 16, 2006
mrDFWmechanic's Avatar
first time i've heard of that
Old Mar 16, 2006
Al Gore FTW's Avatar
jdmtytedoridori
boiler's probably right
Old Mar 16, 2006
Jap-Euro Fusion
I am right. this was on a TSB a while back. the engine, you and the gas tank all favor the left side. Even with you out of the car, the engine and gas tank shift a little weight off center, resulting in the left side lean. Its normal.
Old Mar 16, 2006
Boost_Junkie's Avatar
Boost_Junkie has a spectacular aura aboutBoost_Junkie has a spectacular aura aboutBoost_Junkie has a spectacular aura about
we sit on the left side of our cars...and most time we're alone...so obviously the driver side is gonna settle more therefore be lower
Old Mar 16, 2006
jdm_veloz's Avatar
thnx, u all just solved one of my problems. lol
Old Mar 17, 2006
MajinB's Avatar
Drunken Master-7thgen Ninja
yea mine is a little lower too. but my stuff is not blown. its also on my left back side. so i guess its normal
Old Mar 17, 2006
jdm_veloz's Avatar
nice, i m not alone
Old Mar 17, 2006
genexrocket's Avatar
same here, i just noticed my passenger side is lower from my s-techs
Old Apr 1, 2006
TeamMsP's Avatar
TeamMsP is an unknown quantity at this point
u guys got Teins too i have den for like 3 weeks now and my 2 fronts are higher den da back . but my left front side are about .5 higher den da driver side whys dat?
Old Apr 4, 2006
jdm_veloz's Avatar
u guyz heard of counterfeit tein s techs, the coils prints Ej323425-252 stuff like dat, instead of tein. if you got those, maybe dat why.
Old Apr 5, 2006
xproductionz's Avatar
xproductionz is just really nicexproductionz is just really nicexproductionz is just really nicexproductionz is just really nice
lol.. its weird that i am reading this... my driver side used to be lower than my passenger.. but after my swap since the motor sits on the other side its the passenger side that sits lower now
Old Apr 6, 2006
jdm_veloz's Avatar
lol datz F***ed
edspyhill09
Jun 12, 2016 02:45 PM
mistermenphis22
Apr 3, 2016 08:06 AM
Billybob1963
May 31, 2015 07:37 PM
leon1
Apr 28, 2015 07:32 PM
ej8
Apr 13, 2015 06:36 PM
