best solution for separating tie rod
Old Mar 21, 2006
  #31
tfnaaf's Avatar
BLDNPSI Mod
hold up, you said
whole suspension
NOT just the struts
Old Mar 22, 2006
  #32
cubanmike26's Avatar
As you said, front & rear(removal/re-install of springs + shocks)..it's been making noises like it's not properly indexed, but I'm not sure if it's actually the endlinks so I will remove those and the sway bars first, drive it around then see what's up..
Old Mar 22, 2006
  #33
01HonderCivic's Avatar
Don't be a n00b, search ftw
My suspension has started to make a noise...Only on the Pass front, and only on the compression stroke, Almost like a clunking sound. Don't think it's indexing since it doesn't do it while turning but I'm going to pull them all off and grease them up to see if that does the trick
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
rovafa2002
Sep 28, 2015 06:57 PM
Bruce2
Sep 27, 2015 08:45 PM
260000milesgoal
Sep 25, 2015 07:41 PM
meicalnissyen
Suspension
Sep 24, 2015 09:28 PM
