ok, install/uninstall time
Old Jan 15, 2006
MajinB's Avatar
Drunken Master-7thgen Ninja
Exclamation ok, install/uninstall time
i have a deal im gonna do where i give this guy my stock springs for his tein s techs
ok so if its me and him, he know how to install/uninstall and i don't then how long should it take for us to switch my stocks to his and his s techs to my ride? thanx. any help would be great!
Old Jan 15, 2006
dajackal's Avatar
The Jackal
dajackal will become famous soon enoughdajackal will become famous soon enough
if you have power tools, it should only take you about 4 to 5 hours to switch evrything. if you are going to use manual tools, it should take around all day atleast. it takes that long cause you may have to check the intallation of your springs and make sure everything is put back together. =) GOD speed
Old Jan 15, 2006
Boilermaker1's Avatar
Jap-Euro Fusion
to do 2, working one at a time it'll take 8-10 hours. You'll need to uninstall everything before you can re-install, so make sure you have 8 jack stands, 2 jacks, 4 tie up cables for the front knuckles, etc....
Old Jan 15, 2006
MajinB's Avatar
damn...
Old Jan 15, 2006
booba5185's Avatar
7thgen Terminator Ninja
booba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to behold
there's a diy on it somewhere around here, want me to look or did u find it boris?
Old Jan 15, 2006
mugenman's Avatar
"mmmBAHHHH" - vtec y0
just a lil fyi ur gonna need an alingment bad after u get the springs on. after i lowered my car my rear wheels were so bad they would howl when i turned going like 5 mph so good luck with the spring swap man
Old Jan 15, 2006
MajinB's Avatar
no its not about that at all. i just needed to know estimated times. thanx tho
Old Jan 15, 2006
Axxe's Avatar
Axxe is an unknown quantity at this point
Or you can do the front axle on both cars, then the rears. I could do the whole operation in less than 5 hours.
Old Jan 15, 2006
MajinB's Avatar
are you in GA? thanx for the suggestion. ill keep that in mind actually. it sounds good.
Old Jan 19, 2006
burke420's Avatar
The World Is Yours!
i did my first setup, springs in like 4 hours with power tools, then skunk2's no power tools in like 6.
Old Jan 20, 2006
03-Acura-1.7-EL's Avatar
03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light
Majin, do you want to keep your own shocks and get his springs?
You could just swap strauts, you give him your stockers and you get his lowered assembled... It will take you even less time, may be half less time.
No need to take stuts appart and exchange sprigs...
On my 4dr I took me about 4-5 hours to install lowered springs. Manual tools, 1st time..
Make sure it take struts apart you will have them assembled following froper indexing, otherwise all type of noise will make you sick.
Old Jan 20, 2006
MajinB's Avatar
yes. he basically wants my stock springs for his s techs. i don't want to trade his struts/shocks cause they are more worn than mine while lowered.
thanx for the thought and the time
ImmortalEX
Detailing
78
Sep 4, 2015 05:35 PM
EdGasket
May 25, 2015 01:06 PM
MN-02-CivicEx
28
May 2, 2015 09:11 PM
DC5@EM2
Bolt-on Engine Performance
Dec 4, 2001 07:53 PM
supercivic01
South
Nov 30, 2001 11:27 AM
