springs installed, but..
Old Dec 24, 2005
klectic's Avatar
klectic has a spectacular aura aboutklectic has a spectacular aura aboutklectic has a spectacular aura about
hey guys
i did a search, but not much i could find, and im really wanting to get some answers..i'll try and keep it short.
-bought a pair of used progress springs (used for a year, off the owners car for almost a year)
-wanting to replace my h&r 1.3" drop with these new 1.8-2.0" drop (did my research on this site about progress springs)
-running 17" on 205/45/17
had them installed 3 days ago, but they are sitting the same IF NOT higher than my h&r.. so this got me worried. i know they have to settle in a bit, but i mean to settle down to the 2" drop it has to settle 3 inches?!
the fronts seem ok, but my rear is high, and everyone says progress should drop ur rear..so im confused ??
questions are:
1. do these still need to settle even tho they are used, and for how long?
2. the garage that installed them installed the rear springs with the more compressed part (progressive part) at the bottom, but i thought the more progressive parts are supposed to be near the upper strut (under the wheel well) ? tried to take them out and reverse them, but since they taper, it wont fit on the shock ? could it be for a rsx (as they suggested?) -basically, is it upsidedown?
3. am i worrying over nothing, and time should settle my springs?
i really am curious bc it just wasn't what i expected. i have maybe 2 finger up front, and 3 in the rear..i want the 1.8-2 !!
THANKS A LOT GUYS!
*any pics of how you installed the progress springs would be cool too!
Old Dec 25, 2005
c kim's Avatar
c kim is an unknown quantity at this point
1. yes,the springs need to resettle. whether they are used or not has nothing to do with the springs already being settled in or not. when you decompress a springs, and recompress it, it needs to settle again.
2.the shop is correct. The dead coils are supposed to be at the bottom of the strut/shock. the more compressed part is supposed to be at the bottom.
3. yes, the best thing you can do is just go out and drive the car!
I highly reccomend investing in some new shocks. For that much of a drop, you should get koni's and nothing less. Your stockers won't last long unless you live in a car utopia with no curbs and bumps in the road.
Old Dec 25, 2005
EM2jdm's Avatar
EM2jdm is an unknown quantity at this point
The same thing happened to my buddies 04 coupe the rear had a 2 finger gap and the so did the front but after week or so the springs settled and the fronts had a 1 finger gap and the rear had none.
Old Dec 25, 2005
Rennen's Avatar
New Mod on the Block
i've had my neuspeed springs on my stock shocks for about 9 months now, and they're still going strong . maybe mine are just freaks .
Old Dec 25, 2005
etrof's Avatar
etrof is an unknown quantity at this point
damn ur pretty lucky. usually riding that low on stocks they only last bout a month or three.
Old Dec 25, 2005
eye_see_you's Avatar
let the devil out
my stocks lasted almost two years tucking 17" then I went with tokico and 18" never looked back
Old Dec 25, 2005
c kim's Avatar
Yeah, you could probably last a while runnning neuspeed sports but this guys on progress springs which have a pretty aggressive drop, a little more than neuspeed sports. I'm predicting a bouncy *** ride w/ the progress springs so upgraded struts/shocks would be on my list.
Old Dec 26, 2005
klectic's Avatar
thank you!
i was getting worried that there were many views, but no replies!
thanks for your input guys (ckim) !
speaking of shocks, my front pass is already blown and have looked up on the sticky about shocks..
what is a reasonable priced shock? and is adjustabe necessary for the progress drop? or non adjustable (like the tok. blues) will be ok?
Old Dec 26, 2005
let the devil out
Originally Posted by klectic
thank you!
unless your going for a slammed ride the tokico blue HP struts are awesome. I voted them over my koni's even unless your going Dspec
Old Dec 29, 2005
klectic's Avatar
could it be possible that these are rsx springs? hence they're not sitting right?
Old Dec 29, 2005
ragingSPAM's Avatar
I just burnt my tongue
get koni or i personally recommend d-specs from tokico because they are often times cheaper and better for ride quality
Old Dec 30, 2005
klectic's Avatar
..well it's been around a week since i got them installed
still not a big significant difference
still too short to make a conclusion?
need more time to settle still?
i think the front went a little lower, but my rears are still pretty high (3 finger)
its getting me pissed, bc (like my earlier post) im thinking maybe this is a rsx spring (thats wut my install shop told me it might be)
i bought them used, and there is no part no. on the box or on the springs itself..
suggestions? comments?
Old Jan 3, 2006
klectic's Avatar
anyone shed some light on this for me?
please please please??
or progress sport users, can you tell me how your install looked with these springs?
ive seen many "after" shots, but want to know how it looks ni the beginning, and how long it takes to settle..
thanks!
Old Jan 3, 2006
ragingSPAM's Avatar
thats weird i just installed my H&R's today and im getting a 1 to 1/2 finger gap in the rear and 2 in the front... ( i have oem shocks on front cuz i have to drill out the crashbolt holes on the d-specs and i have d-specs on the rear)
Old Jan 3, 2006
riced's Avatar
riced will become famous soon enoughriced will become famous soon enough
did you install them into a sedan or coupe?
my mechanic told me that RSX (which is a coupe) springs can fit both civic sedan AND coupe, but if you install it in a sedan, the rear will sag..
whenever you install a coupe springs into a sedan, the rear sags, so if that is really RSX springs, it shouldn't cause problem if you drive a coupe, thus, it'll sag in the rear if u drive a sedan.
my wild guess is that, u prolly just bought the wrong springs
it shouldn't take THAT long to let the springs settle.. i don't think any springs would sag and/or settle for 3 god damn inches man !!
Old Jan 3, 2006
ragingSPAM's Avatar
i have an 04 coupe but the springs were used on an 02 sedan (the springs are meant for either coupe or sedan 01-05 except 4 dr EX's)
Old Jan 3, 2006
klectic's Avatar
i have a coupe
..hmm ya i was starting to think the guy sold me rsx spings, although he implied that it was civic springs and told me the drop would be a finger gap front, and tucked in the rear like all the pics i see)
awww man! buyer beware =(
Sep 26, 2023 06:44 PM
mjdiaz89
Jun 21, 2016 09:26 PM
Misfit2613
Jul 30, 2015 09:49 AM
Bill in San Jos
Jul 10, 2015 12:32 PM
Ccoop87
Jul 9, 2015 03:26 PM
