EP3 front shock absorber same as 03-05 non si
Old Dec 21, 2005
ragingSPAM's Avatar
I just burnt my tongue
i was wondering if the ep3 front shocks were the same as the 03-05 em2/es1/2
because my issue is i have ractive coilovers and the rears fit fine on the stock shocks but but my fronts are 55mm strut housing because i have an 04 and the sleeves wont fit over the strut...
since the bottom alignment bolts are 16mm and tokico makes only 14mm ones for the 01-02 if i get the ep3 blues which are 16mm alignment bolts will my ractive sleeves which are 50mm strut based sleeve fit over the strut so i can install it onto my car?
i need this quick cuz riding with coils on the back and stock on front is killing my car and im trying not to drive as much as possible before i get shocks and springs completely installed
Old Dec 21, 2005
Xenin's Avatar
Superior Evolutionary Element Destined-factor
Xenin is an unknown quantity at this point
actually early EP3s have 14mm crashbolts as well.
Old Dec 21, 2005
ragingSPAM's Avatar
ah ic...but on www.hondaautomotiveparts.com they have for the 03-05 16x62 crashbolts...and tokico's website has listed that the si has a slightly different shock
# for the 01-02 is HB3204 and HB3205
while the # for the 02 si is HB3204A and HB3205A (notice the A)
EDIT: i just read that the 02-05 ep3 si's all have 16mm crashbolt sizes which started in 02 than got adapted to the coupes and sedans for 03 which then it used exactly the same setup
Old Dec 21, 2005
ragingSPAM's Avatar
can anyone confirm that the 02-05 ep3 front shocks will fit 03-05 non si's
Old Dec 21, 2005
robbclark1's Avatar
Retired suspension supermod.
They should fit, but you might need new upper mounts. I am not sure though. You will have to look at the schematics from www.hondaautomotiveparts.com
Old Dec 21, 2005
ragingSPAM's Avatar
i did they are the same...so if i get the tokico made for the 02 ep3 than would it fit on my 04 and acommodate my 50 mm coilover sleeves? while having 16mm crashbolts?
Old Dec 21, 2005
robbclark1's Avatar
What sleeves do you have? Some fit, and some don't. I thought 02 Si had 14mm bolt holes?
Old Dec 21, 2005
ragingSPAM's Avatar
i have ractive 50mm sleeves which are meant for the 01-02 with the 50mm struts...i checked and im pretty sure the 02 si ep3 has 16mm which they brought and put on the 03+ all civics...cant be 100% but im pretty sure...so if i get the tokico models for the 02+ si my coilovers and bolt holes should fit correct?
Old Dec 21, 2005
robbclark1's Avatar
I don't know man. The Si might be 55mm. I would call tokico and ask them 1) what the mount holes are for he 02 Si shocks and 2) what size is the shock (50 or 55mm).
The part numbers are the same on tokico's site, but there is an A next to the Si ones. There must be something different about them.
Old Dec 21, 2005
ragingSPAM's Avatar
im pretty sure the a is for the 16mm crashbolt holes cuz tokico wouldnt change the strut if it was for the same car
ill call to make sure
Old Dec 21, 2005
ragingSPAM's Avatar
well i called tokico and they said that the 02 si has the 16mm crash bolt sizes but where the tire rod connects to needs to be drilled out slightly bigger to accomodate the larger tie rod bolt on the 03+
Old Dec 21, 2005
robbclark1's Avatar
alrighty, then you will need to drill out the steering arm. it has to remain tapered.
Old Dec 21, 2005
ragingSPAM's Avatar
also robb i was wondering what size the tie rod is on the 02 si?...cuz i looked on www.hondaautomotiveparts.com and for the 03 si(they dont have 02 listed) its 10mm and the 2001 - 2005 all of the tie rod nuts are 10mm (17mm socket size) i was wondering if it would even require modification to fit
Old Dec 21, 2005
robbclark1's Avatar
I can't even find the Si on there. can you get me both diagrams?
Old Dec 22, 2005
ragingSPAM's Avatar
this is 01 strut (same illustration)
price: http://www.hondaautomotiveparts.com/...SHOCK+ABSORBER
this is 04 strut illustration
this is the 01 tie rod
01 non si parts price link
http://www.hondaautomotiveparts.com/...=P.S.+GEAR+BOX
this is the steering and tie rod picture for the 03 si
03 si parts price and link
http://www.hondaautomotiveparts.com/...+BOX+%28EPS%29
this is the 04 steering and tie rod
04 non si parts price/link
notice on the site for the tie rod nuts it says 10mm
Old Dec 22, 2005
robbclark1's Avatar
Well the nut can still be 10mm and have different inside diameters. The choice you have to make now is where do you want to drill. Either way you are going to be doing some drilling for either the mount holes (if you buy EM2 shocks) or the steering arm (if you buy EP3 shocks). I suggest buying the EM2 ones, and dremmeling the holes. They don't have to be perfect, just as round as you can make them to fit a 16mm bolt through. I say this because although the steering arm can still function without a tapered hole, it is better to have it tapered as not to allow much play. It is hard to tell from these pics the size of the tie rod end. Although my JICs are for the EP3 and they fit fine...
Old Dec 23, 2005
ragingSPAM's Avatar
thanks for the info robb....+ rep for u and i orderd the ep3 ones just because i know a cnc machine shop which can drill it the same exact as my stock ones i rather drill 2 holes slightly bigger then 8 holes heh...just me tho
well i ll try to rep when i can
Old Dec 23, 2005
robbclark1's Avatar
Remember the steering arm holes have to stay tapered.
Old Dec 23, 2005
ragingSPAM's Avatar
robear was charging me too much for them so i canceld the order...now im looking for any used or new shocks for the civic that will fit 04 coupes...i will also trade my stocks and up to $500 in cash for any true coilovers that will fit an 04!!
Old Dec 25, 2005
Civic_Racer9's Avatar
(SnOwBoArDeR | FoReVeR)
i was wondering if i took the whole front/rear shock absober assembly and put it into my 03 civic.
would it fit? crash bolt are the same (16mm) AND the tie rod bolt is (10mm) also the same.
Old Dec 25, 2005
ragingSPAM's Avatar
rears are the same on the rsx, ep3, and 01-05 civics...but the fronts you would prolly need to drill out the steering arm hole to match your oem one...if its different that is...the ep3 originally started with 16mm crash bolts which than later got put on the 03-05s....but im on my search for a full coilover set
Old Dec 25, 2005
and dont all SI have a lower ground cleareance than our civics?
Old Dec 26, 2005
ragingSPAM's Avatar
i think so...but they are basically the same
BootyDo
Jun 21, 2016 03:45 PM
JohnnyBxo
Nov 12, 2015 03:04 PM
7thgensurvivor
38
Aug 29, 2015 11:50 AM
jzhartman
22
Jul 23, 2015 10:42 PM
