suspension help??
Old Dec 15, 2005
bluevtec's Avatar
bluevtec is an unknown quantity at this point
suspension help??
I've got an 02' civic coupe ex model. I've had ground control coilovers on for a year and a half. I just took them off because my rear end was giving and shocks were till good. I contacted ground control and they sent me a replacement. That did not work. Started sagging in rear again. I got so tired of it I put my factory springs back on. Now I'm getting a popping noise on my front right spring. When I first put ground control on I got the same popping noise. I went to my local honda dealer and bought an o- ring that fixed the problem. Now that I have the factory springs back in I went to honda again and bought yet another o-ring thinking it would fix it. It didn't work. Now I'm getting pissed. My friend from Honda has an suspension setup off of a 02'-03' civic si hatchback. I wondering if it will be a direct bolt up or not. I'm just curious and don't know what to do. Any help would be appreciated.
Old Dec 15, 2005
robbclark1's Avatar
Retired suspension supermod.
1) you are on stock shocks and they are probably blow, hence the sagging
2) You did not index the shock and the mount correctly, hence the popping.
It is not GCs fault. It is bad install and bad decision on not get aftermarket shocks.
No, the Si suspension will not fit.
Old Dec 15, 2005
bluevtec's Avatar
ok first off after a year and a half of having the gc's on, THE rear of the car started sagging. The shock was not blown at the time of having the coilovers on. GC sent me replacements for rear and they worked for maybe a week then it to started sagging. Getting fed up with the problem I took the GC's off and put my factory springs back on. Maybe I said shock in my first post but I meant spring setup. After putting my factory springs back on it started popping again just like before when i put the gc's on. I bought a (0-ring) don't really know what its called exactly but it did not work and I still have popping noise with factory springs. I know that its not ground control's problem. I never said it was but you wouuld think that I would have never had a problem since they are McPherson. I was just letting people know why I'm asking if the 02'-03' civic hatchback spring setup will work. I don't really have time to go and take my factory back off to see if they fit or not. I would like to know for sure. Yes I had factory shocks on my car the whole time I had the ground control on my car and never had a problem. Now when I put my factory back on my rear driver side shock blew, but when I had gc on it was my rear passenger side that was sagging.
Old Dec 16, 2005
robbclark1's Avatar
All the shocks are probably weak or almost blown. The rear shocks weaken faster. They may be not "blown" but the are definitely weak from the lowering. Although the front may be heavier, there is less bounce in it than the rear. If you think about it, the rears bounce up and down over bumps putting more stress on stock shocks.
Mcpherson vs DW is not a difference in the shocks. The strut is different, but they still both use shocks. If you look at full coils, you see that the DW vs. Mcpherson shocks are the same, they just have different bottom mounts. Stock shocks lowered on = extra stress.
As for the popping, it doesn't matter what springs you put on it. If you don't index stock shocks and mounts correctly it will pop. There is a thread about indexing in the suspension FAQ.
The Si shocks will fit, but not without some modification. The springs will fit, but they aren't built for the civic's weight distribution and will look funny on your car.
You can not take me seriously and do whatever you choose. I am not trying to be demeaning or mean, but the only solution is to get aftermarket shocks with either your GCs or stock spring (or full coils) and do a CORRECT install. That's all.
Old Dec 16, 2005
bluevtec's Avatar
thanks for your help. At first i thought you were just coming off all wrong. Maybe it was the people that did it for me. I will try to look at the index faq and figure it out. I appreciate it. I will post wahtever i find out.
Old Dec 16, 2005
boostaddict's Avatar
boostaddict is on a distinguished road
Wait, you had ground controls on your car and the springs sagged in and you were not happy with the ride height? Why didnt you just raise the rear ride height via the adjustable collar on the ground controls? Or am I missing something here?
Old Dec 16, 2005
robbclark1's Avatar
They started sagging over time, meaning he thought something was wrong. Raising it up doesn't fix the problem that it wasn't sagging then it was. All it does is make you think the problem is fixed.
Old Dec 18, 2005
bluevtec's Avatar
yes I already had the rearall the way up and the car was still sagging on driver side rear.
Tedverseti
Apr 23, 2020 01:45 PM
Mad Dog Tannen
Oct 19, 2016 08:12 PM
Tedverseti
Sep 29, 2015 05:41 PM
czarlun
Sep 14, 2015 08:16 PM
Mad Dog Tannen
Sep 12, 2015 12:48 AM
