Silly question about dust cover over strut
I just removed all 4 of my struts and have taken one of the front ones apart. Question is, how do you get the rubber boot off of the strut.. I am talking about the rubber dust/debris cover over the strut, the long black one. I thought it would just pull of... I was trying to use a screwdriver and work it over like the bolt or whatever part of the rod is that is right above the top of it, with no luck... I wasn't trying very forcefully and only spent a minute on it... is this the correct way??? All in all so far the project has gone good, with the exception for one of my back struts was a bitch to get off, 500ft/lbs impact wrench wouldn't get it, turns out my strut was bent probably from a wreck... finally got it though... Also, I use a pitman tool to get the tie rod ends off, worked perfectly, didn't bend the bolt or warp the threads... Maybe if I went back to my garage and messed with it, i'd be able to pop that cover right off, but I am at work now and just wondering if someone knows the answer...
Thanks
Brad
Thanks
Brad
Thanks
Thanks for the info.. next all I have to do is finish taking them apart so I can figure out which parts need to be replaced and what struts/springs to go with... daily driver nothing special but choices, choices, choices... Thanks again...
Brad
Brad
Option 2 is always just cutting it off and peeling it away from the strut piston. I think they're about $20 each to buy new ones though.
If I were going to do that, I might as well just leave it on the strut... because the only reason I would take it off would be to re-use it right?? I mean, there aren't any other parts it's gonna help me get to right?
Thanks again for the info.
Brad
Brad
thesushiboy
Jun 4, 2015 03:03 PM
