koni yellow adjustable damper knobs
Old Dec 13, 2005
EastBayStuntN's Avatar
EastBayStuntN is an unknown quantity at this point
koni yellow adjustable damper *****
i wanted to know if the koni yellows come with 4 adjusting damper ***** for the 01+ civic or do they only come with 2 which are placed under the hood?
my set only came with 2 so im curious
Old Dec 13, 2005
Boilermaker1's Avatar
Jap-Euro Fusion
you don't leave the **** on permanently. You adjust and remove it. Its like a key.
Old Dec 13, 2005
robbclark1's Avatar
Retired suspension supermod.
They give you two so you have a spare....
Old Dec 14, 2005
speaking of koni yellows... should the mounting plate be sitting so the cup is upward or pointing downward?
heres a shot i took of the koni yellow rears...
and heres one installed from the gallery from a member here...
http://www.7thgencivic.com/memberrid...&searchid=2565
Old Dec 14, 2005
robbclark1's Avatar
The spring sits on the pearch. You have it upside down.
Old Dec 14, 2005
kinda weird that its sitting face down x_x
are their any other things i should be aware of before installing these with my sleeved coilovers?
Old Dec 14, 2005
Jap-Euro Fusion
Which sleeves?
Old Dec 15, 2005
skunk2 sleeve coilover kit
update: funny thing was...i had these skunk2s on stock struts and i didnt use any o-rings. i did some research here and it seemed like o-rings were neccesary when installing konis. so i let the shop be aware of that and told them to call me if i need them so i can run down autozone to grab some. hours went by...they installed my driver front side with no problem at all. but i had to leave my car overnight because they didnt finish the passenger side by closing time. btw, their installing the fronts and ill be doing rears this weekend
so poor civic is out their in their parking lot getting cold with the front wheels removed. would it help to take a photo of the driver side with the wheel off at the lot and see if you can point out anything wrong? i guess im just anxious
Tedverseti
Apr 23, 2020 01:45 PM
Tedverseti
Sep 29, 2015 05:41 PM
rovafa2002
Sep 28, 2015 06:57 PM
mnewcomb
Air Conditioning
Sep 26, 2015 11:02 PM
Jrosa
Sep 14, 2015 08:24 PM
