These alignment specs alright?
Old Oct 21, 2005
slicksivik's Avatar
i have both front and rear camber kits on this car. looking for good treadlife out of my tires cuz i just bought em. Not too concerned on how fast i can turn with them or what not, just as long as they last there 50k miles. is the left front camber right and what about the toe in the back? thanx
Left front camber -.86
caster 2.00
toe -.03
right front camber -.45
caster 2.50
toe -.05
left rear camber -.67
toe 0.07
right rear camber -.78
toe 0.06
Old Oct 21, 2005
streetglower's Avatar
everything looks ok, except the left front camber is a bit out according to the specs I have from my last alignment. The specs you should have that the shop I go to uses is
Front camber -0.8 / 0.8
Caster 0.6 / 2.6
toe -0.12 / 0.12
Rear camber -1.5 / 0.0
Toe 0.04 / 0.16
I am assuming you just go an alignment? If so, it should show you the specs on the sheet they gave you and usually numbers in red are angles out of spec and numbers in green are angles within spec.
Old Oct 21, 2005
robbclark1's Avatar
Retired suspension supermod.
Everything is in/close to spec, but generally get less camber on the drivers side. That should be fine though.
Old Oct 21, 2005
slicksivik's Avatar
should i take it back and make them fix the front left drivers side? they put... .25 to -1.25 as the specified range.
Old Oct 21, 2005
I think you will be ok. Some shops use a broader range of specs then what honda uses, so as long as it is within that shops specs, you should be ok. As long as on the sheet it shows the spec in green, you are ok. (that is if the sheet is like mine).
Old Oct 21, 2005
slicksivik's Avatar
i think they used the wrong specs, cuz it says 03 civic si, i got an lx.
Old Jan 30, 2006
jdm_veloz's Avatar
jdm_veloz is an unknown quantity at this point
i got a 02 ex coupe, are these specs looking alright??
caster: (L) 1.75 (R) 1.92
camber: (L) -0.75 (R) -0.75
toe: (L) 0.00 (R) 0.00
Old Jan 30, 2006
Boilermaker1's Avatar
Jap-Euro Fusion
They seem alright.
Old Jan 30, 2006
tfnaaf's Avatar
BLDNPSI Mod
They seem alright.
What he said
Tedverseti
Apr 23, 2020 01:45 PM
Tyler93
Detailing
Oct 24, 2015 09:48 PM
Tedverseti
Sep 29, 2015 05:41 PM
Wariogamer
Sep 29, 2015 09:49 AM
NROD315
Sep 4, 2015 09:22 PM
