Dumb Question (Cuz im dumb)
Old Oct 20, 2005
CivicMexicano's Avatar
El Pinche Turbo Mexicano
CivicMexicano is an unknown quantity at this point
I have a set of megan coilovers sitting on my bedroom, and have not installed them cuz i whant to know first how to adjust the camber and the height on thse, i tknow they have a 3rd lock and you can pre load the spring, but what how do i do this, i mean, i really have no fisrt hand expereicne with any of this stuff (live in mexico) and what to know of to do it
also what is the benefit or need of preloading the spings?
Old Oct 20, 2005
PiNoYxRaCeRxRH's Avatar
PiNoYxRaCeRxRH is an unknown quantity at this point
bump
Old Oct 20, 2005
acidbaby's Avatar
The Beez Kneez
try a coilover install search>> prolly in there on how to lock them...
Old Oct 20, 2005
scatman's Avatar
Still in the game...
- put them in
- adjust them till you have the right drop you want
- there is only a way to adjust camber with fronts.......camber is all hype anyway
done deal.
edit cause my memory is going
Old Oct 20, 2005
TeLLy's Avatar
Yes, it's an Acura EL
Originally Posted by scatman
- there is no way to adjust camber with those coilovers, you dont even need to worry about it anyway
done deal.
The front assemblies come with camber plates. Sorry had to correct on that one.
Old Oct 20, 2005
scatman's Avatar
fixed.
Old Oct 20, 2005
TeLLy's Avatar
I agree with the all-hype thing. When the shop was doing my alignment after my Megans were installed, they futzed around with the freakin camber plates for 3 hours. I was just like "screw the camber, fix my toe I have to leave". Was an hour late for work.
Old Oct 20, 2005
Boilermaker1's Avatar
Jap-Euro Fusion
You think its all hype because you either don't drive in any situations it means something, and/or you don't know what you're doing with it.
Anyways. Don't preload the springs, just set the collars so the spring is tight between the collars and the upper mount, but not compressed at all, then tighten the collars in place. the 3rd locknut is tightened against the lower bracket to lock the shock in place. Don't set the camber youself without the proper gauges.
If you cornerweight the car, they'll set the preload, the alignment shop will take care of the plates.
Old Oct 21, 2005
Thanks...
juror
Suspension DIY
Jul 30, 2019 03:28 AM
Supamann
Aug 31, 2015 02:14 PM
Brandon Vlasak
Jul 25, 2015 07:25 PM
NoobyKid
Jul 13, 2015 07:53 AM
beeemerdude
Jul 10, 2015 09:22 PM
