Suspension Help
Old Oct 3, 2005
GACivic's Avatar
GACivic is an unknown quantity at this point
Suspension Help
OK. I have 18" wheels right now with 215/35/18 Nitto NeoGens all around. I want to lower my car like 2 inches or so. I really am not sure how low it should go. I want to do this right, with Springs + Cambers, and whatever else I would need.
So... What kind of springs/cambers should I get? How low will that make my car?
Is there anything besides springs/cambers that I need for my car to lower it, without making my suspension shitty?
Old Oct 3, 2005
MIVtec's Avatar
MIVtec is an unknown quantity at this point
If you want to lower your car 2 inches i would suggest full coilovers and an SPC camber kit. Your stock struts will not hold up to a 2 inch drop no matter what springs you buy, and blown struts = shitty ride. Do some research and find a good set of full coilovers. i bought my spc camber kit for $100 and it works great!, but the coilovers may run you $1,000+ for a quality set of 4.
Old Oct 3, 2005
GACivic's Avatar
What is the difference in a spring and a coilover? So I would have to get Cambers + Springs/Coilovers + Struts?
Old Oct 3, 2005
MIVtec's Avatar
FULL Coilovers are a strut setup that has the strut and spring put together, if you only purchased springs you would just be replacing your stock springs and putting the lowering springs on the stock struts (bad idea). either way you will need a camber kit for the front and rear.
Old Oct 3, 2005
Echelon04's Avatar
The one and only....
Echelon04 is an unknown quantity at this point
Springs and struts are better than coilovers. Unless you want to change your ride height all the time, I would go with springs and struts. Get some Tokico Blues with neuspeed race springs. I think you would like that.
Old Oct 3, 2005
GACivic's Avatar
Any idea where I could get any of this?
Old Oct 3, 2005
robbclark1's Avatar
Retired suspension supermod.
please read the FAQ in my signature, and search the suspension forum. I suggest not buying anying until you realize what it will do to your car. Again, I STRONGLY suggest you do not make any rash purchases because you will regret it. Do your research and don't listen to most of the "opinions." Listen to individuals who have experience and seemingly can answer real factual questions for you.
Old Oct 3, 2005
MIVtec's Avatar
the Tokico blues are only meant to be lowered 1.5 inches other wise it will effect ride quality/blow them.
Old Oct 3, 2005
robbclark1's Avatar
yes he is right
this is the wrong forum to ask suspension questions.
Tedverseti
Apr 23, 2020 01:45 PM
Mad Dog Tannen
Oct 19, 2016 08:12 PM
Tedverseti
Sep 29, 2015 05:41 PM
czarlun
Sep 14, 2015 08:16 PM
Mad Dog Tannen
Sep 12, 2015 12:48 AM
