are 01-03 suspension same as 04-05 suspension?
i was wondering, becuz i bought 01-03 coilover sleeves for my 05 civic. i was just wondering if they would work, or would it not work,
i don't mean to sound like a noob, but better safe than sorry,
they should work just fine. the only real difference between the 03 to the 05's is the body style front and back bumpers etc. the engine bay and suspension setup are the same. Im in the same boat I have an 05 EX SE working on suspension myself after i get some more cash to blow
i've read much about the 50 // 55 mm front shock thingy, what exactly are we measuring? the 2 fatty *** bolts on the front shock that hold it to the front axle? the distance between the 2 bolts? or what? the thickness of the bolt? i got kinda confused, someone clarify plz.
Originally Posted by PCaly2112
so if someone were to buy my suspension setup (55mm) which is koni yellows with my strut housings off my '04 with <a href="http://www.serverlogic3.com/lm/rtl3.asp?k=eibach%20springs" onmouseover="window.status='eibach springs'; return true;" onmouseout="window.status=''; return true;">eibach springs</a> it could fit an '02?
i read that you can put the RSX front struts or something, cuz they're 55mm or something.. can someone confirm that?
does Koni make any other struts that fit the 03-05 civic other than the yellow? i've only seen yellow. i just want a low looking ride without the freaken bumpy a$$ ride.
so if someone were to buy my suspension setup (55mm) which is koni yellows with my strut housings off my '04 with eibach springs it could fit an '02?
Koni only makes the yellow for the RSX/EP3/EM/ES. They don't make too many applications of anything else because the yellow is simply so popular, durable, flexable and reliable. You can use RSX struts because they have the 16mm crash bolts, but they're no more durable or receptive to lowering than the shocks already on the car. Its not exactly an upgrade, its more of a lateral move.
im a psychopath...what are you looking at?
2001-2003 or 2003-2005 have the same basic setup when it comes to suspension...the main difference between the two is the exterior and some interior redesigned. the 03 has the exterior of an 01-02 vics while the it has the interior of an 04-05. i have an 03 and used and 01-02 setup and works perfectly fine...secondly, 01-05 have the same chasis...sooooooo 01-02 setups can fit 04-05
Touch it... He won't bite, He'll just come at you pretty quick.
not sure if anyone covered it yet but... the lower front bolts that mount the strut to the control arm in the front are smaller on 01-03's and bigger on 04-05's so you need to drill them out a bit, a drill press works wonders in this case.
There is waaaay too much misinformation in this thread.
ALL 2001 models have 50mm struts and 14mm crash bolts. The upper bearing is also different from the 2002-2005 bearings.
Sometime in 2002, honda figured out there was an issue with the struts, rather than **** around with it, they homologated the Si and EM/ES parts pile, and began using the 55mm struts that seemed to be more durable than the 50mm ones. There is no way of telling whether a given 2002 has 50 or 55 mm housings, its random as they phased them in and cleared the old stockpile of 50s out, therefore you must measure your housings. 2002s have 14mm crash bolts and the revised upper bearing that fixed the steering knock issue on the 01s.
By the 2003 model year it is believed that ALL the cars have 55mm struts. More homolgation took place and the 03s adopted the 16mm knuckles and crash bolts from the Si.
2004 and 2005 saw no major changes to the suspension.
2001 and 2002 are directly interchangeable
2003-2005 are directly interchangeable
2001 and 2002 struts can be modified to fit an 03-05 by drilling out the holes in the strut bracket, or by adding a 1mm sleeve to the knuckle bore.
2003-2005 struts CANNOT be used in 01 or 02 model year cars.
We're done here.
We're done here.
Re: are 01-03 suspension same as 04-05 suspension?
^^ I just learned this issue putting struts in yesterday. 01-02 struts in my 03. For future reference, not only do they require being drilled out larger they seem to lack the ABS line mount as well.
Ultra Havoc
Sep 9, 2015 10:58 PM
