camber plates :p
Old Aug 18, 2005
Zzyzx's Avatar
Autocross Junky
camber plates :p
So I finally broke down and bought some camber plates... now that Hotchkiss "Finally" droped the price on them to a reasonable level... $187.47 Vs the original price of $374.95
http://www.hotchkistuning.com/cgi-bi...atalogno=30704
Just got them to day... I'd have to say that I have yet to be unsatisfied with the build quality of any thing I've purchased form Hotchkis (I have their 25.4mm rear anti-roll bar). Only thing I'm worried about would be what I have to modify to make them work with my Neuspeed struttower bar.
Now, if I can talk my friend in to parting wiht his ground controls....
Picks soon, when I'm not being lazy.
Old Aug 18, 2005
streetglower's Avatar
Let us know how they work.
Old Aug 18, 2005
Boilermaker1's Avatar
Jap-Euro Fusion
I wish you luck. I know there's not much you can do and retain the OEM spring size, but be careful with the over/under sandwich type orientation of the plates... they can be very fickle and fragile.
Old Aug 18, 2005
Zzyzx's Avatar
Autocross Junky
THey arnt going in for a while... I'm trying to work a deal with a friend who has some Ground controls. though they are the ones designed for the OEM dampers not konis.
Just piecing the suspension together one part at a time.
Old Aug 18, 2005
ojay's Avatar
ojay is on a distinguished road
sick. what else you planned in your setup?
Old Aug 19, 2005
Zzyzx's Avatar
Autocross Junky
I'm about to the point of how much more $$ do I want to put in to a car thats not going to make me Compeditive... So, going to ground control springs is probably the last thing I do. aside from tweaking the spring rates on the ground controls a bit.
OH ya, Going to have to get rear suspension bushings soon too... as the OEM ones are completly shot at this point.
Old Aug 26, 2005
cranny's Avatar
cranny is an unknown quantity at this point
Honestly Zzyzx , you could have made them on your own from scratch. depending on tools available i guess and knoledge of metal.
Old Aug 26, 2005
Zzyzx's Avatar
Autocross Junky
True, but I dont have a lathe, Mill or other needed tools to make a set.... I have been thinking about Modifying them (replacing the Aluminum top) with a Steel one that would allow Caster adjustments.... all in good time.
Old Aug 26, 2005
Jap-Euro Fusion
Its a fairly precision part. It would take some pretty good machining knowhow (you'd need a mill, a lathe and a press for the pillowball) and a good CNC to make an identical pair. By the time you went through the trouble.... $175 isn't so bad.
Old Aug 26, 2005
wonderz's Avatar
wonderz is on a distinguished road
are these Hotchkis better than the Tein ones?
or any reason why you buy these instead of the Tein ones?
Old Aug 26, 2005
Jap-Euro Fusion
The tein ones are of a better design. I doubt the quality of construction is any different between the two. The hotchkis ones bolt right on, where as the tein ones need custom hardware.
Old Aug 26, 2005
Zzyzx's Avatar
Autocross Junky
There is also the difference that the Tein ones have a pillow ball mount and the Hotchkis ones are of a more "stock" style with Derlin rather then rubber as the isolator
Old Aug 28, 2005
cranny's Avatar
very true boiler not a bad price at all , and zzyxz i agree with replacing with a metal one , specialy if you like honda induced g force, haha.
Old Aug 28, 2005
Jap-Euro Fusion
Post ***** much?
Jeez
Dave Brabant
20
Oct 6, 2015 12:44 AM
Tedverseti
Sep 29, 2015 05:41 PM
meicalnissyen
Suspension
Sep 24, 2015 09:28 PM
beanhead
Sep 24, 2015 12:04 PM
