Strut blown? Alignment & Balancing didn't help
Old Jul 6, 2005
sleeper2002's Avatar
sleeper2002 is an unknown quantity at this point
My 2002 Civic EX sedan has been pulling to the right. It is very noticable. I have had my wheels balanced and a four wheel alignment but neither fixed the problem.
I'm thinking that the right front strut is blown (from the direction it pulls). If I need to replace the strut would it be 55mm or 50mm? Thanks
Old Jul 6, 2005
robbclark1's Avatar
Retired suspension supermod.
We can't tell you. You have to measure it. Honda changed the strut size randomly.
Old Jul 7, 2005
Ok thanks. Do you know if a blown strut could be my problem?
Old Jul 7, 2005
BSonly's Avatar
BSonly is an unknown quantity at this point
Same here. My front passenger side leaked at 35,6xx right before the warranty ended and Honda replaced it for me. Now at 69,xxx the same one started leaking. SUCKs that Honda only warranty the replace shock for 1year or 12000 miles. My car also a 02 ex sedan pulls to the right and the tire is bald on the inner side as if my car was lowered. I plan to buy the ebay set of shocks for $315(shipped).
Old Jul 7, 2005
Well, my car is leased and it was brand new when I got it. It has 32,xxx miles do you know if they will replace the strut? My lease ends at the end of 2006 so I still have a little while left and I don't want to be driving around like this.
Old Jul 7, 2005
BSonly's Avatar
They should! I took mine in and the tech drove it and all we did was turn and go over a speed bump and he pulled it back in to the garage and said that they would take care of free of charge. GOOD LUCK to ya!
Old Jul 7, 2005
KnocturnalEM2's Avatar
I am your Mom's Hero!!
that could be the reason why, sounds logical, Honda should cover it!!!
Old Jul 7, 2005
flotsamm's Avatar
Rotate the front wheels and tires to the rear and test drive. Sometimes it can be a bad tire that wont be detected by balancing.
Old Jul 7, 2005
nitroal1973's Avatar
Broken Road......
nitroal1973 is a name known to allnitroal1973 is a name known to allnitroal1973 is a name known to allnitroal1973 is a name known to allnitroal1973 is a name known to allnitroal1973 is a name known to allnitroal1973 is a name known to allnitroal1973 is a name known to all
If you have an alignment print out, post it up, or at least the numbers. There are a few of us that can understand some of that stuff. But like someone else said, it may be a bad tire.
7thgensurvivor
38
Aug 29, 2015 11:50 AM
honda200192
May 31, 2015 05:57 PM
GH04si
Apr 15, 2015 08:13 PM
CapYoda
Jan 7, 2002 03:20 PM
RickyRocket
Nov 30, 2001 10:14 AM
