Proper way to adjust height for TEIN SS
Old Jun 4, 2005
chocobo15_2000's Avatar
§C§H§O§C§O§B§O
chocobo15_2000 is an unknown quantity at this point
Okay, i've always wondered, the TEIN SS/SS-P have 2 perches to lock the spring, and the FLEX has a 3rd perch to adjust height without changing the preload, which means for SS/SS-P owners like me, we have to adjust the height which changes the preload on the spring.
what is the proper way for us to adjust the height? cause if you just crank the top lock nut all the way up, doesn't it just compress the spring? and not actually raise the height? Does the strut rod actually get pushed up when you raise the spring up? or how does that work mechanically?
Old Jun 4, 2005
Boilermaker1's Avatar
Jap-Euro Fusion
They're not preloadable. Just lower the perch the spring comes down, you lower the car and the piston goes further into the strut. The lower you go, the less shock travel you get.
Old Jun 4, 2005
§C§H§O§C§O§B§O
i'm actually trying to raise the height, so the piston will come futher out of the strut? in my case, i think the piston is at the furthest point, cause i tried to raise the height more, and the locking rings were soooo damn hard to turn, felt like i was over compressing my springs, so I stopped. I lower the car back down, and its only a 1 finger gap!
i thought the tein's can have your ride at a stock height? is there something i did wrong?
Old Jun 4, 2005
robbclark1's Avatar
Retired suspension supermod.
no coilovers ride stock height. They drop at least 1". Look at tein's site for the minimium they will drop.
Old Jun 4, 2005
§C§H§O§C§O§B§O
okay, but 1 in drop will still be 2-3 finger gap, and i can't seem to get it up that high, its already very hard for me to twist the perch up higher, i dont know if i'm doing something wrong.
Old Jun 5, 2005
robbclark1's Avatar
pics would help
Old Jun 5, 2005
CivicMexicano's Avatar
El Pinche Turbo Mexicano
CivicMexicano is an unknown quantity at this point
**delete**
Old Jun 6, 2005
§C§H§O§C§O§B§O
i'll try to get some, my digicam is out of whack >_<
Old Jun 6, 2005
skipbarber's Avatar
loosen the strut bolt. I was surprised how high the SS go. May not be stock height, but damn close.
Old Jun 6, 2005
§C§H§O§C§O§B§O
strut bolt? do you have a diagram as to which piece that is? will i have to remove the assembly to loosen it?
Old Jun 6, 2005
hustlelikem0fo's Avatar
the rear is a huge paint in the *** to raise up because you have to fight the loaded spring even when the car is raised. now the fronts however, when the car is raised the spring becomes loose becuase its not loaded and the front is much easier to adjust when going up. if you're having a hard time raising the rear then nothign is wrong cuz thats how it is with my SS
Old Jun 7, 2005
§C§H§O§C§O§B§O
my fronts are hard to raise as well =/
Old Jun 12, 2005
rijowysock's Avatar
ThE FaMiLy SeDaN
i love my flex..
spring is never loose..
but when u raise perches ur lenthening the shock travel=decreasing preload
and vice versa
im doing flex on my s2k too.. so.. YES!!!
Old Jun 13, 2005
§C§H§O§C§O§B§O
wow, grats riley! ^_^ nice upgrade
skeener51
Oct 1, 2015 05:56 PM
Tedverseti
Sep 29, 2015 05:41 PM
rovafa2002
Sep 28, 2015 06:57 PM
mnewcomb
Air Conditioning
Sep 26, 2015 11:02 PM
TheRiddicles
Sep 21, 2015 01:28 AM
