Will rsx stock shocks fit our cars?
Old Jun 12, 2005
leonhsieh's Avatar
leonhsieh is an unknown quantity at this point
My friend just put the coilover on his rsx s. I was wondering will the shocks from rsx s fit on our car? I have neuspeed sport spring on my sedan and the ride is really bouncy with stock shock. I was thinking those shocks might improve ride quality.
Old Jun 12, 2005
BiGDoG's Avatar
BiGDoG is on a distinguished road
I Dont Think So, Dont Qoute Me Though
Old Jun 13, 2005
robbclark1's Avatar
Retired suspension supermod.
Yes, but it may or may not be worth the money. If you have an 03+ than your mount bolts should be 16mm. that is good because RSX shocks are 16mm. If you have 01-02 then you have 14mm and you will need an adapter kit (but I am not sure if they sell it separately). You also will need new tie rod ends. The DC5 tie rod ends are larger so you will need to get a set of those. Those are $70 from www.hondautomotiveparts.com You can try to see if the tie rods fit, but I think the hole in the strut will be too large for the civic tie rod end.
The upper mount also may be different. I don't know much about upper mounts so I can't give you any more info than that.
Old Jun 13, 2005
leonhsieh's Avatar
ic...thx for the info
Poopies
Apr 20, 2017 11:36 PM
Rardon6thgenCiv
Apr 15, 2015 07:37 PM
Thees1
Apr 14, 2015 08:23 AM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
