OMG!! Installed TEIN BASIC but got a problem..
Old Apr 13, 2005
ohl85's Avatar
ohl85 is an unknown quantity at this point
Hi.
Just installed TEIN BASIC last Monday.(03 civic coupe EX)
But it makes loud noise from the front whenever I turn the wheel.
The mechanic told me that it's a normal sound for 7thgen coilovers and it will go away after few days. Also the preowner of coilover told me that the noise will go away after few days, but it will come back whenever the weather is cold.
hummm.. What should I do? It's really loud and so stressful.
Is there any solution that I can do for it?
-STEVE
Old Apr 13, 2005
dirtySAMURAI's Avatar
I log in from time to time
are you sure you put the upper mounts on correctly?
Old Apr 13, 2005
Yoyoio's Avatar
Yoyoio is an unknown quantity at this point
i got basic, i don't have sounds
you using your bearing?
Old Apr 13, 2005
snowboreddave's Avatar
snowboreddave is an unknown quantity at this point
yeah, the sounds are ok.. i had em on my SS Tein coilovers. Josh Jacquot ( editor of S. compact car) took a look at my car and told me ill be ok but if i wanted to take apart my coilovers and reinstall them just to be 100% certain then to do it but it was no big deal. he said all coilovers make noises, no matter from what company or line.
Old Apr 13, 2005
ohl85's Avatar
I'm not sure about the bearings....
hummm... should I bring my car to other car to check it out?
Old Apr 13, 2005
skipbarber's Avatar
my tein SS have never even made so much as a squeak. I don't think noises from coilovers are normal.
who installed the basics? when does the noise happen?
Old Apr 13, 2005
ohl85's Avatar
It happens whenever I turn my steeringwheel. (parking, and turning at intersection etc.. happens at low speed).
humm... its so stressful.
Old Apr 14, 2005
HellSpawn's Avatar
HellSpawn is an unknown quantity at this point
I hope they dont make noise. Im getting mine installed Monday!
Maybe contact Tein to see what they have to say? If this is something
that is normal then I would think they would say so. I guess?
Old Apr 14, 2005
03CivicEX03's Avatar
03CivicEX03 should not be trusted03CivicEX03 should not be trusted
hmm.. never happen to me i have 03 coupe. I replace my 03 to 01 upper mount and bearing
For it order to make the noise go away. You need 2001 upper mount and bearing. Go do a search.
Old Apr 14, 2005
flipbagz's Avatar
Go Pistons!
flipbagz is an unknown quantity at this point
lol me t00
Old Apr 18, 2005
HellSpawn's Avatar
Update.. Got them (Teins basics) installed and I dont have any noise from the front. However I do hear noise from the back when I go over small bumps. Im thinking that might be normal due to the spring compressing to deal with bumps in the road.
Since Im a newbie Im not sure exactly what to expect in terms of noise levels but man the car drives like a dream! Im amazed at how the car handles from a 2inch drop!
Old Apr 18, 2005
scatman's Avatar
Still in the game...
its just the springs settling in, dont worry.
Old Apr 18, 2005
HellSpawn's Avatar
Thanks Scatman. Im glad to hear that!
I have to go back next week and get a camber kit but its the best grand I have spent so far.
Old Apr 19, 2005
flyers27's Avatar
Broad Street Bullies
flyers27 is an unknown quantity at this point
make sure you cut your dust covers in the rears. im dropped on basics and cut ther dust boot before i installed them and they still made noise. then i went back and almost cut the entire dust boot off..... i think i left about an inch on it and no more thumping when i hit bumps. try it
Old Apr 19, 2005
HellSpawn's Avatar
Hell I guess you guys are right. Today I drove the car and the rear springs are not making nearly the same amount of noise as yesterday.
Old Apr 19, 2005
pnoyster2k1cvic's Avatar
Balut Eating Champ
kinda noise? thud, squeek, rattle?
Old Apr 19, 2005
HellSpawn's Avatar
I would say its closer to a bad bed sping noise. Its sounds like a hotel bed during rought sex (not to offend anyone ( - :=
Hopefully its gone for good.
Old Apr 19, 2005
Balut Eating Champ
ow ok... i have the same noise, but it's more like a minimal bed spring noise during rough sex w/ out the headboard hitting the wall noise... I think it's the rubber coating on the spring that makes that noise... i just turn my music louder
Old Apr 19, 2005
HellSpawn's Avatar
Funny I guess great minds must think alike. I did the same thing on the way home. Its amazing what loud music can do.
Old Apr 20, 2005
djspot's Avatar
fuk tha man!
djspot is an unknown quantity at this point
Im pretty sure its your dust covers, cut them about an .5-1" and you'll be good, ASSUMING thats your problem, I had a sound sorta like the sound you get when you crush a soda can...if thats the sound, then your problem is what I mentioned above...otherwise my tein's dont make any noise whatsoever
Old Apr 20, 2005
gh0st's Avatar
TAQUITOS!!!!
won't 01 upper mounts fix this?
Old Apr 20, 2005
flipbagz's Avatar
Go Pistons!
tein has revised ones,,, they give you two sets of rings,, green is for 01 and for 02+ u use the gold ones.
Old Apr 21, 2005
flyers27's Avatar
there shouldnt be any noise from the upper mounts..assuming you have the right ones installed. Green is for after sept. 03 and gold is before sept. 03. the upper mount issue is for the fronts. if the noise is coming from the rear, then you have to cut the dust boots. i cut mine on time before i put the coilovers together only one inch and it wasnt enough. i still got noise coming from the rear. then i cut them an inch more and the noise is gone. the noise is the spring compressing over bump and the dust boot hitting the bottom of the shock where the bumpstop is. just cut the whole thing from the start.
Old Apr 21, 2005
Boost_Junkie's Avatar
Boost_Junkie has a spectacular aura aboutBoost_Junkie has a spectacular aura aboutBoost_Junkie has a spectacular aura about
has anyone come up with a solution w/ tein basics for what to use for the 04/05...do the stock upper mounts work?
Old Apr 21, 2005
flyers27's Avatar
tein supplies you with the upper mounts now. two different sets, 01-03 and 04-05.
READ THE PREVIOUS POSTS!!!!
Old Apr 22, 2005
actually nope...i asked ed(truehonda) then emailed tein, the basics for 04/05 dont supply you with the upper mounts
Old Apr 22, 2005
flyers27's Avatar
i dont care what he said. its BULL....i just put mine on a week ago. I have an 05. they have two different sets of upper mounts that they send you in the box. One set for 01-03 (gold) and another for 04-05 (green). dont know who you talked to at TEIN but i made sure before i ordered mine that they would come with the upper mounts and they also told me they would.
GO HERE AND SEE FOR YOURSELF (installation manual) page #7
http://www.tein.com/ti/inst/la22u.pdf
Old Apr 22, 2005
sabbathiel's Avatar
sabbathiel is an unknown quantity at this point
That's because you asked the wrong thing... Tein doesn't replace the upper mount, they replace the spring seat that goes inside the upper mount... the green one (part #USS01-H2735) is for 2004+ Civics and the gold one (part #USS01-E1242) is for 2001-2003 Civics.
SuperEF
Jun 24, 2015 11:53 PM
cukaracha
Jun 7, 2015 03:32 PM
reqy
Jun 1, 2015 07:05 AM
elitezdc5
May 26, 2015 05:46 PM
