Pro Kit vs Sportline
Old Apr 15, 2005
  #31
CiViCLiZeD714's Avatar
I have had the prokit for 1 year+ with stock struts. I am also riding on 225/40/18s.
Old Apr 15, 2005
  #32
lxcivic2k1's Avatar
Originally Posted by Cascino
LX, you should read up alot about upgrading shocks, as they say in the suspension topics when dealin with sportlines, it's all different with peple shocks. it basically comes down to luck. If you have the money i highly recomend the Koni front and rear shocks with the sportlines, its the closest to stock if not the same. this will give you that low look that you want and will keep you satisfied with the ride plus no worries about blown shocks. if the ride is an issue go with Prokit. Im going with the prokit, cuz i dont want to upgrade my shocks and in PA i cant go that low. hope this helps
it does...thank you..now i have to remember to factor in the shocks because the last thing i need is to get a bad shock on a long trip.....have to see if i can get the parents to cover it
Old Apr 17, 2005
  #33
obguam's Avatar
obguam is an unknown quantity at this point
Tell parents its a safety issue. Must install good aftermarket shocks (Tokiko's or KYB) with lowering springs so you don't make same mistake countless others have, which is the whole point of this website -- or one of them. Search word: "blown".
Old Apr 18, 2005
  #34
Derrik's Avatar
Derrik is an unknown quantity at this point
hey, instead of creatin a new thread mind as well ask here...my local rim/suspension place carries the sportline and prokit... my car is ridign on 15s (stock tire size) and i wnat to get rid of my gap would the prokit be suffishent enough or would the sportline be the way to go? thanks, or just save for coilovers haha.
Old Apr 18, 2005
  #35
flotsamm's Avatar
If your 15's are stock size, then the prokit will do. If your 15's are smaller, you might want to consider the sportlines.
Old Apr 19, 2005
  #36
Cascino's Avatar
04 Black EX
Cascino is an unknown quantity at this point
more than likely Prokit. if your stayin stock anyways and just want the gap covered, just go with prokit, the easiest route and will look clean
Old Apr 21, 2005
  #37
Blue2K1Girl's Avatar
Blue2K1Girl is an unknown quantity at this point
Originally Posted by PennyKnotOff
You'll need to replace your shocks. The sooner the better but w/ the prokit they should last longer and one other thing is you will need a camber kit if you don't want to be replacing tires every year. I suggest the SPC camber kit
I agree with this whole post. If you're gonna go with the Pro-Kit, I recommend some new shocks within a year, if not a little sooner. I started noticing a little too much bounciness in my ride about a year after I got my springs.
I also do NOT recommend an Ingalls camber kit. I've had mine fixed twice, but it still makes noise (somewhere on there, I think a bolt is sliding on an arm, if that makes sense). I need to replace it.
Edit: I have 215/45/17s.
Tedverseti
Sep 29, 2015 05:41 PM
Hutch1051
Sep 29, 2015 09:20 AM
anubis62
Sep 27, 2015 12:56 AM
krazykoncepts
Sep 8, 2015 09:02 PM
Chameleonman
Bolt-on Engine Performance
Sep 5, 2015 04:06 AM
