SPC camber kit SQEEKS?
Old Apr 12, 2005
Yoyoio's Avatar
Yoyoio is an unknown quantity at this point
anybody have problem with spc camber kit sqeeking? Installed my tein basic and spc camber kit for 2 weeks now. today, there's a mad sqeeking from the driver rear suspension area. I m suspecting it is the spc camber kit.
anyone got a fix to it?
thx
Old Apr 12, 2005
robbclark1's Avatar
Retired suspension supermod.
uh put some grease on the bushings and make sure everything it tight.
Old Apr 12, 2005
peteriap's Avatar
peteriap will become famous soon enoughpeteriap will become famous soon enough
^^ Thats it. If in fact it is your camber kit squeaking.
Old Apr 12, 2005
Yoyoio's Avatar
are you suspecting something else that is sqeeking? it won't be the dust cover from tein, because i cut them off already.
Old Apr 12, 2005
streetglower's Avatar
thx
Let me ask you this, when you installed the camber kit, did you tighten the bolts on it while the vehicle was jacked up? Or did you loosely install them, then lower the car, then tighten the bolts?
to me it sounds like you preloaded the bushings.
Old Apr 12, 2005
FaiJai's Avatar
FaiJai is an unknown quantity at this point
^^ what do you mean preloaded?
Old Apr 13, 2005
Yoyoio's Avatar
i preload the suspenion first than tighten the bolt up. so i m pretty sure i didn't preload the bushing.
The sound keep coming and going.... i think i should take it off and re-install
Old Apr 13, 2005
chocobo15_2000's Avatar
§C§H§O§C§O§B§O
chocobo15_2000 is an unknown quantity at this point
i'm having some squeeking after i installed my TEIN SS-P's .. i've had a rear camber kit for a long time, and it wasn't until i installed the teins did i hear the squeeking, and yes it only comes from the rear. SHould i just rub some greese all over the joints just to make sure?
and i heard if you cut the dust covers on the teins, you void the warrantee... be careful bro, those things are expensive, you want that warantee
Old Apr 13, 2005
Yoyoio's Avatar
i m gonna rub some grease on tomorrow to see if that helps. The sqeek is going off and on now for some reason.
coilover were bought over a yr now, i don't think i have any warrante left. Besides i got it used in mint condition for 1/3 of the price
Old Apr 13, 2005
§C§H§O§C§O§B§O
^^^ ic ic i'll try the grease too, after i trim my dust boot 1/2 an inch shorter
Old Apr 13, 2005
truehonda's Avatar
truehonda has a spectacular aura abouttruehonda has a spectacular aura about
Like everyone said, grease em and it will go away.
Old Apr 13, 2005
Yoyoio's Avatar
greased them today, nothing sqeeking YET, i'll have to see in a couple of days
Dave Brabant
20
Oct 6, 2015 12:44 AM
Tedverseti
Sep 29, 2015 05:41 PM
Hutch1051
Sep 29, 2015 09:20 AM
anubis62
Sep 27, 2015 12:56 AM
meicalnissyen
Suspension
Sep 24, 2015 09:28 PM
