installed my Tein Basic's today...got a problem
Old Apr 9, 2005
djspot's Avatar
fuk tha man!
djspot is an unknown quantity at this point
so I installed them this afternoon, I've driven around for agout 5-10 miles...I went over some bumpy road, nothing serious...and now I got a seriously loud grinding/clinging type of sound from the back right coilover...its really late so I cant take everything apart, however I opend up the trunk put my hand around the upper assembly and I can feel its something inside there, the issue is up at the upper mount....anybody knwo what this could be? its really bothering me....anybody hear of this problem or experienced it?
its really loud by the way.....
Old Apr 9, 2005
chocobo15_2000's Avatar
§C§H§O§C§O§B§O
chocobo15_2000 is an unknown quantity at this point
so you have tein basics with tein upper mounts? or u using the stock upper mounts?
Old Apr 9, 2005
civicvtec1ps's Avatar
Search and Learn
Did you cut the factory isolator on rear?
Old Apr 10, 2005
djspot's Avatar
fuk tha man!
I have the stock mounts....
what exactly is that??? what isolator? I didnt cut anything when I installed them I just took the pieces the instruction tell me to reuse nad installed them...the back left is fine...just the back right started making this sound...
Old Apr 10, 2005
K20me's Avatar
You have to trim the dust boot if its the rear. It's plastic and it's supposed to keep the shock clean from dirt. I trimmed mine about 1/2" and it no longer made the nasty sound (kind of like when you crush cans, that sound). I suggest cutting both of the rear dust boots cause eventually the other one will also make the sounds.
Old Apr 10, 2005
djspot's Avatar
fuk tha man!
thanks very much! Just did it, sound is gone and yeah the plastic was all fuked up at the very bottom...they should tell u that shyt in the instructions
Old May 9, 2005
Initial D's Avatar
Initial D is an unknown quantity at this point
I just got my tein basics installed too. I have that loud noise from the rear too. Sooo embrassing!!! When I drove around. Well instead of cutting the rear dust boot, can i install the camber kit? Will that solve the problem too? The place I bought it from they said just cut it! No need to buy soft dust boot or camber kit!!! Should I listen to them?
Old May 9, 2005
Search and Learn
Installing rear camber kit won't solve the problem.
All you have to do is trim dust boot to get rid of rear noise.
mistermenphis22
Apr 3, 2016 08:06 AM
elitezdc5
May 26, 2015 05:46 PM
Youshoe
May 22, 2015 09:36 PM
bsmiley
Apr 27, 2015 01:27 PM
