Alignment Specs
Alignment Specs
I got my car realigned this time I had them put it were I wanted it (almost).
Front: L R
camber- -1.4 -1
toe- 0 0
caster- 3 2
Rear:
camber- -0.3 -0.3
toe- 0.06 0.07
I could not get the front perfect becuase I don't have a frront camber kit. I am not sure why the right is different than the left, but I don't think it is that far off that it will make a difference.
For those that know how to make our car handle what do you think about these #s?
Front: L R
camber- -1.4 -1
toe- 0 0
caster- 3 2
Rear:
camber- -0.3 -0.3
toe- 0.06 0.07
^^^Well I just put the car sideways in the middle of the corner on Reynolds just past Door. I was not trying to either. I just sort of took the corner fast and the backend steped out. Scared the **** out of me and my gf who was in the car at the time. It was suprisingly controlable though
Its not gonna handle very well, but it should be ok. There should be some slop in the front knuckle to play with. not enough to make up .4 deg, but if the alignment guys played with it some, they might get it a little more even. You'd do better with a bit more camber in the rear.
I reduce the tire pressure in the rear and it seemed to make it more neutral
thanks.
Originally Posted by bgoetz
Do you think that this setup is going to be more prone to oversteer??
could you give us some good alinment specs to go with...
thanks.
thanks.
Front: -2.25 1/16" toe out
Rear: -1.5ish 0 toe
Like I said.... tires don't like it, the handling does.
TheRiddicles
Sep 21, 2015 01:28 AM
