Install Tein Flex. Having problems
Old Apr 2, 2005
ManUtd0018's Avatar
ManUtd0018 is an unknown quantity at this point
I installed my tein flex coilovers last night and it dropped the hell out of my car; more than i really wanted to. Anyway, the camber and toe are way off. It's so bad that i can't even drive to the alignment shop. I have the camber kits installed but it is the toe that is off. Both tires are facing inwards (towards the engine). While viewing the car from the back, you can see about two inches of the back of the front tires as they face inwards.
What should i do?
Old Apr 2, 2005
dannn's Avatar
unique conformist
dannn will become famous soon enough
cant you just raise the car back up to stock and then drive it
Old Apr 2, 2005
ManUtd0018's Avatar
Do you mean to uninstall the coilovers and re install the stock ones. I must be confused.
Deception2k1civic said, "i do alingments all the time. to adjust rear toe you must turn an ecentric bolt on the lower control arm. first loosen the 17mm bolt. then turn the ecentric bolt with a 24mm to your desired spec. the front you just turn the tie rods. loosen then locking bolt with 24mm and turn the tie rod with a 19mm. you also can adjust front camber a little bit with the stock bolts. rear camber on the other hand you need a kit for it."
Old Apr 2, 2005
shmik1's Avatar
he means adjust the coilovers to not be so low
Old Apr 2, 2005
dannn's Avatar
unique conformist
yea why dont you just raise it back up drive to the shop then drop it again then have them fix everything
Old Apr 2, 2005
robbclark1's Avatar
Retired suspension supermod.
You have camber plates in the front, use them. Set the camber more positive and drive. I drove with bad negative camber and bad toe to get mine aligned. Just drive really slow. It will feel really bad, but drive slow and take your time.
Old Apr 2, 2005
Boilermaker1's Avatar
Jap-Euro Fusion
Well... you could just shorten the tie rods enough to pull the wheels more straight, then drive it to the alignment shop then let them fix it. Or push the camber plates positive, drive it then spec out what camber and toe angles you want.
Old Apr 2, 2005
rijowysock's Avatar
ThE FaMiLy SeDaN
read this
hey man i had same problem., ur pillowball mounts in front come set at HELLA negative camber in the front.. i had same problem first time... jack the car up.... look at the top... and set the little line to the 0 in rthe middle.
that will set camber at a minimal and toe pretty straight.
right now i still have a little toe... 3/16 in ima get it adjusted monday...
im 2 little lines inward from the 0 and im looking at aboit 7 degrees negative camber which i like... thats just me.. the 0 should put it close to zero.
riley
im me if any more problems
rijowysock =aim
pics below...
i actually in the front removed 2 of the 3 perches today (locking the one that holds spring directly to the bottom mount... eliminating 2 because b4 i had all 3 together anyway...
anywho...this is max max max max drop.. lol.. show some pics once u get urs all done..
ID:	51108   Click image for larger version
ID:	51109   Click image for larger version
Old Apr 2, 2005
rijowysock's Avatar
ThE FaMiLy SeDaN
see my chrome bolts r in the middle (or near middle)
Old Apr 2, 2005
robbclark1's Avatar
Originally Posted by rijowysock
read this
riley
rijowysock =aim
7 degrees!! Wow, who would have thought you can get 7 degrees!! You can't!! haha I think you mean .7 degrees
Old Apr 2, 2005
rijowysock's Avatar
ThE FaMiLy SeDaN
no 7 their like sideways but i have to have em like that cuz the fenders...
the rears are about the same cause fenders...
pics above...the guy at align place was yellin at me and like holy ****.. but i told him leave camber and juts adjust toe... which he screwed up 3/16in but thatl be fixed monday...
btw i swapped my 12kg/mm front springs to 10kg/mm
if anyone wants 12kg/mm springs lemme know
Old Apr 2, 2005
robbclark1's Avatar
You can't have negative 7 degrees camber. You would it the shock/spring with that much camber. It is impossible. The max you could get is probably 4 or 5. 3 is even pushing it.
Old Apr 2, 2005
rijowysock's Avatar
ThE FaMiLy SeDaN
maybe he meant .7? idk he told me 7 and yelled at me saying ima bust something but i got neogen and they wear fine
Old Apr 2, 2005
skipbarber's Avatar
why not just undo the lock nut on the tie-rod ends and spin them shorter? then get your alignment done and have them fine tune it. It seems like the most practical thing to do.
Old Apr 3, 2005
rijowysock's Avatar
ThE FaMiLy SeDaN
well if he would change his camber plates they would turn out perfect.... and no need to undo lock nut
Old Apr 4, 2005
ManUtd0018's Avatar
By the time i read to adjust the camber plates i had already shortened the steering rods.
4 banger
Jun 5, 2015 01:44 AM
elitezdc5
May 26, 2015 05:46 PM
Youshoe
May 22, 2015 09:36 PM
Flatlander
Nov 16, 2001 05:38 PM
