Need help from suspension guru's....
Old Mar 31, 2005
K20EQUIPPED's Avatar
K20EQUIPPED is an unknown quantity at this point
Question Need help from suspension guru's....
I just installed my Neuspeed sports on my 01 coupe now that winter is over, and just had the struts replaced under warranty from Honda...now after they have been instaleld when I turn left or right there is a knocking noise coming from the front...and it wasnt there last summer. I brough it back to the installer who did them last year also and he cannot see anything either....anyone have a problem like this before? If so is there a fix for it...
Any help would be appriciated...I am stumped myself.
Old Mar 31, 2005
mallison's Avatar
mallison is an unknown quantity at this point
i know this maint sound stupid but if it knocks when you turn and or brake it could be that 1. you might have a wheel weight hitting or 2. loose lug nuts, which both has happened to me before, something else that could be a possibility is a bent axle or coupling or yoke or something of that nature or bad bearings somewhere
Old Mar 31, 2005
definatley not the lugs as I torqued them, bearings no, coupling maybe, Im putting new brakes on this weekend....so I will take a look myself under the car....Just really pissing me off...
Old Mar 31, 2005
skipbarber's Avatar
i had a similar problem with my neuspeed sport springs. Whenever I turned the wheel, it would make a knocking sound right before it hit the maximum from lock to lock. It turned out that the springs were seated wrong. I re-seated them and the noise went away.
Old Mar 31, 2005
c kim's Avatar
c kim is an unknown quantity at this point
Did they index the struts? That might be the problem.
I can't believe your warranty wasn't voided from changing the suspension. Very fortunate for you.
Old Apr 2, 2005
What is index the struts? and the stock springs were in for the winter so I had the struts replaced before the lowering springs were but on
Old Apr 2, 2005
robbclark1's Avatar
Retired suspension supermod.
http://www.7thgencivic.com/forums/sh...ighlight=index
Old Apr 5, 2005
Em2Guy's Avatar
Em2Guy is an unknown quantity at this point
hmmmmmm... on an 01 you have to line up the springs on the top mount and fold the tabs over the spring . thats what my guess is on that noise. its is very often over looked.
Tedverseti
Apr 23, 2020 01:45 PM
Mad Dog Tannen
Oct 19, 2016 08:12 PM
Tedverseti
Sep 29, 2015 05:41 PM
czarlun
Sep 14, 2015 08:16 PM
Mad Dog Tannen
Sep 12, 2015 12:48 AM
