Noise when turning ??
Old Mar 12, 2005
GaryC17's Avatar
GaryC17 is an unknown quantity at this point
Hi all, recently I started experiencing some noise from my right suspension when turning while driving at very low speeds. Its a creaking sound. I am lowered on Neuspeed springs with konis. There has only been coil binding noises since, but over the last few days this other noise surfaced. I jacked my car and found alot of grease leaking from my CV joint boot cover. Could it be my CV joint is whacked ? Will replacing the boot and repacking it with grease do any good ? I believe it shouldn't be a suspension problem for I have been driving on the Neuspeeds and konis for sometime with no such sound occurrences. Unless my upper mount bearings are spoilt. Anyone facing such a problem ? Please advise.
Old Mar 12, 2005
dean's Avatar
dean is an unknown quantity at this point
bro.... where is this CV joint located??? think must check mine also....
Old Mar 12, 2005
Nodnero's Avatar
It might be your actual power steering mechanism. Had basically the same thing happen with another of my cars (not the vic) and I was sure that it was the CV joint. Turns out it was the power steering and I had to get that replaced. Hopefully its under warranty for you still, it ran $1300 for a 98 528i BMW.
Old Mar 13, 2005
TSSCivic's Avatar
TSSCivic is an unknown quantity at this point
You will hear a slight ticking sound whenever you made a turn when the CV boots are needing to be replace. If you see a lot of grease around the boot then definitely you need to replace the boot.
Old Mar 14, 2005
GaryC17's Avatar
Okay thanks, I'll look into replacing those boots at the same time get my clutch replaced.
Old Mar 14, 2005
GaryC17's Avatar
Its just behind the disc brakes. Its the joint on the end of the drive shaft that connects to the disc brakes which in turn moves the car. Damn my clutch is due. Jerking at low RPM. I guess this is where the car starts to require major repairs. Now you know why its 3 years or 100k km whichever first.
Old Mar 14, 2005
dean's Avatar
btw, the so call 'boot' , is it the rubber flexible thing ?? so where u gonna get it repair??? KM ??? checked mine few days back, still in good condition , i think...... so which side is yours leaking grease ???
Old Mar 15, 2005
darklegacy540's Avatar
darklegacy540 is on a distinguished road
I too, have that ticking sound when I turn right.. It's been that way for about a year now and I got it checked out and the garage couldn't find anything wrong.. any other ideas?
Old Mar 15, 2005
GaryC17's Avatar
Mine is on the driver's side.
Old Mar 17, 2005
Yellow ES8's Avatar
Yellow ES8 is an unknown quantity at this point
I think a pair of covers for the joints cost around S$80.Vulnerable part of the car,must replace.
Old Mar 17, 2005
GaryC17's Avatar
You replaced before ? Could you define what you mean by a pair ? There are two boots for the drive shaft. One inner and the other for the outer(cv joint).
Old Mar 17, 2005
Yellow ES8's Avatar
oh sorry...I'm refering the the dress-up cover.mine broken last time...was quote around 80 for a set.
Old Mar 18, 2005
dean's Avatar
sianz.... man , my 'crook' sound getting more & more frequent while turning....
Old Mar 19, 2005
I'm thinking about going to a different Honda dealership and seeing what they say. Because this **** should be under warranty. But then again, they might say something gay about my sway bars or something dumb
rtachs
Jul 16, 2015 05:32 PM
civicns
May 8, 2015 09:49 PM
edgenet
May 2, 2015 08:00 PM
SSMatey
Apr 13, 2015 06:09 PM
opticalvetc
Jan 1, 2002 08:32 PM
