Symptoms of a bad upper mount?
Old Mar 10, 2005
BoSS's Avatar
BoSS is an unknown quantity at this point
Symptoms of a bad upper mount. What are they? because I might be needing to buy new ones. And i've searched. And what company makes them? other then Tein and OEM.
I get this vibration in the steering wheel and a sound that sounds like my wheels are hopping over roads relatively flat. Similar to a rattle
Old Mar 10, 2005
VNlilMAN's Avatar
The Standard One
coil bind. when you turn the wheel and it kinda stays that way. or when you turn the wheel and you hear a springy noise.
Vibration in steering wheel? all the time or at certain speeds? when did you start getting all this? did you hit something or install something? It doesnt sound like its the upper mount. kinda sounds like you just dropped your car and arent used to it.
Old Mar 10, 2005
BoSS's Avatar
Thanks for replying.
I'm dropped on Sportlines with blown struts, Its been making this sound even b4 the sportlines about 6000 miles ago. I should mention that I hear the noise when the car is going straight at all speeds. Its like springy sound, like the wheel is bouncing on and off the road. Hard to discribe but its a pretty loud noise. Sounds like the whole suspension assembly is woubling in there. Hard to discribe. I liked to know becasue im a Do it yourselfer and my Tokicos are on the way and I wasnt sure if its neccessary to buy new upper mounts or not
Old Mar 11, 2005
streetglower's Avatar
there is your problem right there, you have blown struts. Your car isnt going to ride like a dream with blown struts. I bet once you change them, your problem will go away.
Old Mar 11, 2005
VNlilMAN's Avatar
The Standard One
"like the wheel is bouncing on and off the road"
that is probably caused by the blown strut.. I wouldnt be surprised if the noise and vibration were because of it too.
but yeah it definitely doesnt sound like its the uppermount at all...
Old Mar 11, 2005
djmota's Avatar
get some new struts all the way around, then get an alignment. these 2 things will make worlds of difference.
lilrob1213
37
Jun 29, 2015 06:45 PM
pincookie1
May 4, 2015 12:22 PM
MN-02-CivicEx
28
May 2, 2015 09:11 PM
GH04si
Apr 15, 2015 08:13 PM
veloce
Nov 10, 2001 01:19 PM
