steering wheel vibration help!
Old Mar 10, 2005
Ever since the accident, the steering wheel will vibrate alot going 65+mph. It gets worse the faster you go, and there was nothing before (I could go to 90mph without vibration). So here's what I've done so far...also I have lowering springs and camber kit.
--had honda check suspension, said it was fine
--balanced wheels, said two were off
--fixed rear sway bar
Now the vibration is still there. I'm gonna get an alignment check again, even tho I just got one right before the accident. I don't know what else it could be. Someone said the tires might have a bald spot from when I smashed the brakes, or the shocks might be going out and making the wheel bounce. Please help I can't drive the car like this!
Old Mar 10, 2005
VNlilMAN's Avatar
The Standard One
try rotating the tires front to back.. if it still vibrates, yeah it might be the alignment
Old Mar 11, 2005
doubledeuce2k2's Avatar
did you rotate tires regularly before?
my gf had a similar problem. she hadn't rotated her tires in about 10k miles. she had 2 that were bad, and 2 that were pretty new. but since she didn't rotate, she got what is called chopping on her tires. i thought it was BS so i went to the garage and looked. basically, the tread on the "good" tires was uneven. inside, outside, everywhere, the wear pattern was horrible. so we had to replace all 4 tires because of the point it had gotten to. run your hand across the tires and see if you feel differences in wear. i wish i had pictures, there was like a 1/8 inch difference in tread between 2 spots that were maybe 2 inchs apart.
i don't think alignment is going to make the car vibrate. if it did, it'd start much sooner than 65mph.
Old Mar 11, 2005
VTECTypeR's Avatar
They could have done a bad balance. Thats what usually happens. They dont balance it right. Might want to look into that again as well
Old Mar 11, 2005
Ya if they did...I'm going back to sam's club for another refund. I bet they did. I'm taking it to a REAL repair shop to have everything checked.
GotSiR
Jun 23, 2016 04:06 PM
OptimisticWay
46
Oct 15, 2015 02:16 PM
kaashifv
Interior
Jul 27, 2015 05:28 PM
breanna_17
Jul 21, 2015 04:01 PM
qlitten
Jul 21, 2015 03:12 PM
