bushings?
Old Mar 6, 2005
flyers27's Avatar
Broad Street Bullies
flyers27 is an unknown quantity at this point
bushings?
OK, if i buy a RSX 19mm sway bar with just the rubber bushings will they fit in the oem mounting brackets for the bushings on my civic, or do i need the brackets off the RSX as well? Will they fit the oem holes? Or, do i have to buy a whole new set of aftermarket bushings and plates. Where could i get it from? I am going to buy a sway bar and just want to know what else i need before i go to put it on.
thanks
Old Mar 6, 2005
Boilermaker1's Avatar
Jap-Euro Fusion
The acura factory bushings fit in the honda bracket. Its the same part on both cars.
Old Mar 6, 2005
flyers27's Avatar
ok so all ineed from the guy that i am buying it from is the bar and the rubber bushings. should i get a set of aftermarket bushings and bracket? I was reading that people were getting "energy suspension" bushings. Where could i get them?
Old Mar 6, 2005
Jap-Euro Fusion
You can get ES bushings from Jeg's or Summit. They're just generic 3/4" swaybar bushings with brackets, they're just a little harder than the rubber ones, I didn't notice much difference between the 2.
ThatGuy913
Sep 28, 2015 05:35 PM
meicalnissyen
Suspension
Sep 24, 2015 09:28 PM
beanhead
Sep 24, 2015 12:04 PM
TheRiddicles
Sep 21, 2015 01:28 AM
czarlun
Sep 14, 2015 08:16 PM
