How far away from specs...
Old Feb 25, 2005
Haywood Jablome's Avatar
Haywood Jablome is an unknown quantity at this point
...do you need to be so you know that you need a camber kit?
I looked in FAQ and couldnt find anything there.
Old Feb 25, 2005
nitroal1973's Avatar
Broken Road......
nitroal1973 is a name known to allnitroal1973 is a name known to allnitroal1973 is a name known to allnitroal1973 is a name known to allnitroal1973 is a name known to allnitroal1973 is a name known to allnitroal1973 is a name known to allnitroal1973 is a name known to all
Have you had the car aligned yet?? If so, get us the numbers. If you have lowered the car at all, I would invest in the kit. It will insure you don't chew thru the tires rapidly.
Old Feb 25, 2005
I did. The place said the back tire readings dont print (WTF?), but I got the front:
Left Camber: 0.1
Right Camber: -1.3
Left Caster: 2.9
Right Caster: 2.3
Left Toe: -.06
Right Toe: .02
Old Feb 25, 2005
Boilermaker1's Avatar
Jap-Euro Fusion
if your left camber is that far off the right, you need to adjust your crash bolts. If the left can be brought back in, then you should also be able to bring the right back. You *NEED* camber kits when your toe can no longer be zeroed because the steering arm runs out of travel. Most people do it well before that to save tires.
sinfulinside
Buy, Sell, & Trade - Archive
Jan 11, 2009 01:40 PM
marcdel
Nov 22, 2007 01:37 AM
LoneWolf
Florida
Nov 21, 2007 04:26 PM
LoneWolf
Nov 21, 2007 04:23 PM
WhosYoDadday85
Apr 3, 2002 05:10 PM
