rsx sway and tie bar question
Old Feb 25, 2005
D17thgen's Avatar
D17thgen has a spectacular aura aboutD17thgen has a spectacular aura aboutD17thgen has a spectacular aura about
would i have issues with an upgraded rear sway bar (perferably 19mm rsx sway) and/or rear lower tie bars rubbing against anything after installation?
i have a buddy who just upgraded to a progress bar and hes giving me his rsx sway for my EX. he has problems with his progress bar rubbing against his exhaust/muffler.
Old Feb 25, 2005
Nameless's Avatar
TURTLEonK
Nameless is a jewel in the roughNameless is a jewel in the roughNameless is a jewel in the roughNameless is a jewel in the rough
u should be fine... My axel back is 2.25 piping and it clears with the RSX 19mm swaybar.. and it was fine with stock muffler too...
should be no problem.. tie bars dont really do much i believe..
good luck!
Old Feb 25, 2005
PicCoLoboi02's Avatar
PicCoLoboi02 is on a distinguished road
my Thermal back then banged against the muffler/exhaust so i had to add new hangers for it to hang lower...i had a kit anyways so it was all good.
Old Feb 25, 2005
Boggie1688's Avatar
Diamond Member
Boggie1688 is an unknown quantity at this point
If ur exhaust is stock...u should be fine. If its not just run down to the local muffler shop and have them bend it a little to clear the sway, or u can place a rubber hose around the area of the sway bar that hits the muffler. I recently installed a 22mm on my stock EX and it clears fine.
Old Feb 25, 2005
bobsagator's Avatar
bobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of light
The RSX bar will not rub against anything stock, as long is you don't install it upsidedown. I will be putting on my Apexi WSII soon and don't expect any problems.
Old Feb 26, 2005
D17thgen's Avatar
thanks for the replies.
my exhaust setup is an apexi world sport exhaust if it matters? anyone have that same exhaust and rsx sway? i belive the piping is 2.4" -+
so tie bar would have nothing to do with rubbing the muffler/exhaust?
Old Feb 26, 2005
Nameless's Avatar
TURTLEonK
tie bar will not have any clearance issues..
Sep 26, 2023 06:44 PM
juror
Suspension DIY
Jul 30, 2019 03:28 AM
Bounddyy
19
Jul 20, 2015 02:42 PM
NoobyKid
Jul 13, 2015 07:53 AM
fordover
Jul 11, 2015 09:10 PM
