perch sliding itself on the coilover
Old Jan 21, 2005
jttegx's Avatar
OMNES AD UNUM
im dropped on sleeved coilovers with stock shocks and im having problems with the perch sliding downward of the coilover so its making one side of my car lower than the other. their is still some leftover grease/lube on the coilover itself and on the top mount plates and under the spring itself. im not sure if that can be one of its issues but someone enlighten me im tired of adjusting my coilovers higher every month
thanks
Old Jan 21, 2005
StreetLevelPerformance's Avatar
Your Parts Guy
StreetLevelPerformance is on a distinguished road
thanks
What coilovers are these? You should have at least 2 perches that lock together when you turn them against each other.
Old Jan 21, 2005
dirtySAMURAI's Avatar
I log in from time to time
If it's ground control then there is only 1 perch that is "locked" onto the sleeve. I think it's the same with skunk2's. You might want to check that your perch is properly tightened. If it's not tight, make it tight.
Old Jan 21, 2005
jttegx's Avatar
OMNES AD UNUM
its tight alright, it'll prob take few weeks til then it starts working its way down. and their skunk2 coilovers, forgot to mention.
do you think it can be the leftover grease/lube on the coilover?
Old Jan 21, 2005
i dont know what to tell you...that's an odd problem.
Old Jan 22, 2005
d17a2outlaw's Avatar
d17a2outlaw is an unknown quantity at this point
always happens to me every 3 weeks i have to adjust the damn things. at first i thought skunk2 was cool. but look at my thread i made here in the suspension forum. booo skunk is junk!
Old Jan 24, 2005
Profoxcg's Avatar
Profoxcg is an unknown quantity at this point
get some BLUE thread locker and apply it the threads of the sleves. do not use too much. MAKE SURE YOU USE THE BLUE kind and NOT the RED.. RED is permanent...
Tedverseti
Apr 23, 2020 01:45 PM
GolNat
Nov 27, 2018 03:32 PM
Tedverseti
Sep 29, 2015 05:41 PM
ThatGuy913
Sep 28, 2015 05:35 PM
beanhead
Sep 24, 2015 12:04 PM
