D2 banging, Progress spring swap?
Old Jan 17, 2005
AzNmiKex215's Avatar
2k1civic.com O. G.
okay so i have the D2 banging issue. Im trying to fix it the most costless way possible.
Some ppl don't have banging with D2 and short rear springs, but i beleive this is so becuase they dont have a ton of stereo and MDF in their trunk like i do.
I beleive the rear spring is supposed to be 8k in stiffness but its extremely short to allow for lowering.
I pretty much narrowed it down to needing a taller spring that is atleast 8K in stiffness.
I have some left over rear progress springs. Would this fit?
The representative at progress told me the springs are rated.
Spring rates are:
front 145#/in
rear 350#/in
What does that equal in the "K" measurement? Which i beleive is kg/mm ? WOuld the rear progress spring be stiff enough? I know for a fact its taller then my current short spring/helper spring combo.
Old Jan 17, 2005
robbclark1's Avatar
Retired suspension supermod.
If the springs on the D2s are linear then progress springs won't work. Plus they are probably taller and wider than the D2s. I would have to say no.
Old Jan 17, 2005
2k1civic.com O. G.
hmm good info, i guess i will just have to order a new set of springs.
Old Jan 18, 2005
robbclark1's Avatar
full coilover springs are different than regular springs. The regular springs have to work with the McPherson strut whereas coilover springs are not as wide because they have their own perch.
Old Jan 18, 2005
Boilermaker1's Avatar
Jap-Euro Fusion
I've got a set of 9K 8" springs, 2.5" OD. if they'll fit, PM me, we'll talk.
Old Jan 18, 2005
2k1civic.com O. G.
Thats what my new short spring looked like. It was about 8 inches in hieght without any load. But that "helper" spring compressed to be like 1 or 1.5 inches high. its always compressed under the cars weight. So the overall spring under normal car load is really short. This makes my strut travel minimal. Even more so with actual people and stereo or groceries in the rear.
UrbanImport beleives the springs are 2.5 inch in diametere so it will work. PM'ed You!
Old Jan 18, 2005
Jap-Euro Fusion
It sounds like the problem you have is that you don't have enough spring rate. Going to a longer spring with the same rate won't do a whole lot, it'll still compress quite a bit in a static position. If you've got a lot of weight in the trunk, you probably ought to look into a heavier rate to support the extra weight.
Old Jan 18, 2005
robbclark1's Avatar
Mike has junk in the trunk...shake what your momma gave ya! haha. I agree with boilermaker. seems like you are bottoming out. A taller, heavier spring might help.
Sep 26, 2023 06:44 PM
2005seTO
Aug 18, 2015 12:45 PM
Mr.Beefy
Aug 12, 2015 04:39 PM
Curtchuk
Aug 5, 2015 02:14 PM
NROD315
Jul 21, 2015 07:46 PM
