Camber kit Question!
Old Jan 13, 2005
matt_s's Avatar
Super JDM Member
matt_s is an unknown quantity at this point
hey im putting on progress springs with 215/45 tires, and i heard the back rubs with a camber kit. I was curious if ne1 here does NOT have a camber kit.. have you noticed any excessive tire wear, i know i should get one, but ive read about many cases where people have not had any problems with our cars. anything you could offer would be great. thanks
Old Jan 13, 2005
tfnaaf's Avatar
BLDNPSI Mod
i would suggest the camber kit if the rear camber is out of specs. Best senario is to have the alignment checked if its out buy the kit, if adjusting it causes the tire to rub then back it off just till it dont rub and mantain the best possible camber setting. And dont forget camber isnt the main tire wearing factor on front or back, TOE is !!!! So as far as that goes can you get by with out the kit YES! Will you get better tire wear with the camber kit ? Most likely yes!
Old Jan 14, 2005
nitroal1973's Avatar
Broken Road......
nitroal1973 is a name known to allnitroal1973 is a name known to allnitroal1973 is a name known to allnitroal1973 is a name known to allnitroal1973 is a name known to allnitroal1973 is a name known to allnitroal1973 is a name known to allnitroal1973 is a name known to all
Uhhh.......excessive camber WILL cause severe tire wear. Toe is not the only tire wearing angle there is.
Old Jan 14, 2005
tfnaaf's Avatar
BLDNPSI Mod
Originally Posted by nitroal1973
And dont forget camber isn't the main tire wearing factor on front or back, TOE is !!!!
Please re-read my post pay attention to words in red. I never said that camber wont wear tires, but that toe is a much more important tire wearing factor. Ive been doing alignments for over 18 years i know what will and wont cause tire wear even in spec on camber on certain cars will get tire wear that is caused from camber. But nine times out of ten TOE is more important then camber as far as tire wearing and nine times out of ten toe is overlooked on this message forum all they seem to be concerned about is camber. I was just pointing out the importance of toe as a reminder!
Old Jan 14, 2005
low04's Avatar
low04 is an unknown quantity at this point
you may have a hard time getting 215/45 tires under there. i have 205-40 and i have about a 1 finger gap
Old Jan 14, 2005
matt_s's Avatar
Super JDM Member
just curious... what exactly is toe? and my buddy does have a 2" drop in the back on 45's he's fine.. but he has no camber kit.
Old Jan 14, 2005
tfnaaf's Avatar
BLDNPSI Mod
This is toe...
Old Jan 14, 2005
matt_s's Avatar
Super JDM Member
ohh ic... thanks for that... now once i go for my alignment after lowering .. lets say i did have a problem.. would they be able to point it out.. or would i specifially have to ask them if this problem exists?
Old Jan 14, 2005
2K1Civic17"Gabe's Avatar
They will tell you. I am putting my camber kit on tomorrow, I hope I can get it pretty da** straight. I just got an alignment. It was only 80 bucks though. My toe is perfect, camber -3
Old Jan 14, 2005
tfnaaf's Avatar
BLDNPSI Mod
If they cant see the problem then they shouldnt be doing alignments. You shouldnt need to ask them to do thier job, be sure to ask for a print out and ask what the warranty is on before you have it done. If you have questions post what they aligned it to.
Old Jan 15, 2005
Mr.Modify's Avatar
i never took my car in for a alignment when i put my camber kit on myself and my stock tires lasted at least 20k
GolNat
Jan 12, 2021 09:06 PM
civic98?
Aug 13, 2015 01:32 AM
j-chest
Jul 31, 2015 01:18 PM
NoobyKid
Jul 13, 2015 07:53 AM
chrisjackson321
Jul 12, 2015 03:00 PM
