Tie rod end question *FIXED*
Old Jan 12, 2005
2002excpe's Avatar
Have you seen Mike Hunt?
2002excpe will become famous soon enough
What is the easiest way to get the tie rod end off? I need to replace mine as I am a dumbass and damaged the threads.
I was able to muscle it off, and put the new tie rod end on, yippeee!!
Old Jan 12, 2005
AzNmiKex215's Avatar
2k1civic.com O. G.
I'm not sure, but how did you damage the threads? From experience I know that tie rods are pretty strong. They just basically unscrew off.
Old Jan 12, 2005
2002excpe's Avatar
^^ Mr. Hammer. I located a new tie rod end for $58, I'll be installing it today
Old Jan 12, 2005
VNlilMAN's Avatar
The Standard One
-keep the whole strut in place
-loosen the nut thats right next to the tie rod
-remove the tie rod from the strut using a tie rod puller(not seperator) you can rent it from autozone for free
-now take off the tie rod by turning it(count how many turns it takes to take it off).
-put on the new tie rod with the number of turns you got from above.
and hopefully you know the rest...
Old Jan 12, 2005
PunkingCivic's Avatar
I need TP for my bunghole
it is $37 here
http://www.hondaautomotiveparts.com/...=P.S.+GEAR+BOX
# 7 in the pic
Old Jan 12, 2005
2002excpe's Avatar
Originally Posted by PunkingCivic
Thanks, but my car is stuck in my garage so I had to get one ASAP. Also, I can't seem to get the fvcking tie rod end off of the tie rod. I removed the strut to get more room to work. The freakin nut behind the tie rod end won't budge, I'm getting pissed and starting to throw tools.
Old Jan 15, 2005
2k1civic.com O. G.
use some liquid wrench or WD40 lubricant. Hold the tie rod with a wrench and hold the bolt with a wrench, Twist in different ways to get it loose. Brace your wrench on something and try to knock it loose.
Old Jan 16, 2005
VNlilMAN's Avatar
The Standard One
eh make sure your turning the right way
Old Jan 16, 2005
tfnaaf's Avatar
BLDNPSI Mod
get the alignment checked after replacing it too, even counting threads can be off!
hans.pcguy
Jul 12, 2015 12:19 PM
mrohitredd
May 28, 2015 10:03 AM
tomg
May 21, 2015 07:05 AM
pheaton
May 4, 2015 08:26 PM
El_Spic
Apr 23, 2015 03:14 PM
