Weird Noise
Weird Noise
I have the tein basic coilovers and this is my first week with them. I am getting a grinding, squeeking noise from the right rear. It has gotten worse over the past few days. At first it would just make noise over big bumps, now it does it when somebody just gets in the passenger seat.
what the hells the dust boots? thanx, ig ot the same problem with my b&g's. its so f'ing annoying, every dip and bump, its like squeeek squeek squeek, ahhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh hhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh
oh wait, can someone get a picture of this dust boot cover thingamagig so i kno what it is when i go to the place to tell them what to do and kno they did it? thanx that'd help me ou ta whole lot
the squeaking is caused by your stock struts bottoming out and hitting the rubber bumpstop. makes sense, rubber combined with the added pressure of lowering springs = squeaking, especially in cold weather.
inifinte i think were talking about aftermarket coilovers and yea is it the dust boot cover, the rubber things we cut and how much or is it the bumpstops that we need to cut? i heard if u cut the bumpstops it might bottom out and hit the body of the car. help would be appreciated cuz im getting this done tomorrow morning.
no thats not the dust boots. the dust boots is the hard plastic tube between the spring and shock they are only in the rear. the front ones you dont need to do anything with them. the bump stops can be cut if you are using aftermarket springs. but if you have full true coil overs they are already the right length from the factory. on the dust boots i cut mine about an inch. hope that helps some if hit up the rep
WaryDriver
Aug 22, 2015 06:50 PM
15EXCoupe
Jul 30, 2015 12:59 PM
BootyDo
Jul 26, 2015 10:38 AM
1khilari
Jul 9, 2015 08:12 PM
