suspension upgrade questions
Old Nov 22, 2004
ricergribbs's Avatar
ricergribbs is an unknown quantity at this point
ok well im starting to upgrade my suspension. i have a 01 LX coupe and so far i have a rear strut bar lol. i had the front one on but it created too much body roll so i took it off for now. i have a progress front sway bar on the way so the strut bar will be going back on once the sway bar is installed. next i want to get into the shocks/springs. what would u guys recommend? coilovers or a spring/shock combo? oh i would like to drop it 1.25"-1.5". maybe a bit more not sure whatll look good but most likely not over 1.5".
Old Nov 22, 2004
Zzyzx's Avatar
Autocross Junky
um.... Couple of things..
1. Chassis reinforcents have no effect on body roll. that is controled entirly by the springs, shocks and Antiroll bars. (If you are trying to make the car handle better, you shouldnt be paying much attention to body roll, but rather how the car is actually handling, as in Is the car understeering? oversteering? ect...)
2. If you are increasing the size of the front anti-roll bar you are going to increase understeer.
are you sure you have a rear strut bar or did you change the Rear anti-roll bar?
Other wise, what are you planning on doing with the car, is this a Daily driver, or something you plan on autocrossing or Open tracking?
Old Nov 22, 2004
robbclark1's Avatar
Retired suspension supermod.
1) read the suspension FAQ
2) read the Suspension tuning 101 in the Autox forum. Read all the links that are posted!
That will provide you with a lot of background info. Read that first, figure out what you want to do with the car and then ask questions.
Old Nov 22, 2004
oh sry for not mentioning somme of that stuff. i want to do some open track but other then that just daily driving. and zzyzx dont ask me why, but when i put the front strut bar on it did increase body roll if i had the rear one on too, and my car doesnt have a rear sway bar, and yes i know the difference between the two. also, when i put the rear strut bar on it actually has a slight bit of oversteer now, which suprised me since thats all i changed. and i didnt actually know that enlarging the front sway bar would increase understeer. and yes the car did handle better with the front strut bar on, but i didnt like it for now since i wasnt going to the track.
Old Nov 22, 2004
ok and i just read the FAQ and i knew all of that stuff, i actually read it before, but it still doesnt answer my question since im just asking what have other ppl found to be good. im doing research . ok ill change my question a bit though. are the hayame full coilovers a good buy? or should i spend the extra cash and get the Tein SS?
Old Nov 22, 2004
Zzyzx's Avatar
Autocross Junky
Well, Your going to get alot of opinions....
but I've Found this setup to be very fun.... assuming you don't spin.
1. Eibach sportlines (yes they are soft, but then its a DD car..)
2. Koni Adjustible shocks (Full soft on the front, 1/4 up form full soft on the rear for street use, autocross = Full soft on the front and 1/2 Turn down from full hard on the rear adjust as nessisary)
3. OEM 03+ 15.9mm front anti-roll bar, Hotchkis 25.4mm 2 point adjustible Rear anti roll bar(Set on full stiff).
In the Hayame Vs SS.... Take the SS, as they have adjustible dampers.
Old Nov 22, 2004
shmik1's Avatar
I have sportlines on tokicos but all i do is DD no track, I love it..
Old Nov 22, 2004
i cant use the rear anti rollbar zzyzx. LX's dont come with it, ill prolly just stick with the progress front and see how it goes, if i dont like it i can always sell it. ill go with the Tein SS too if they have the dampers, didnt realize the hayames didnt. your setup does sound fun though lol, got some nice oversteer dont u?
Old Nov 22, 2004
Zzyzx's Avatar
Autocross Junky
Progress makes an adapter kit for the LX so you can run a rear anti-roll bar.
Old Nov 22, 2004
robbclark1's Avatar
Like zzyzx said, you will get alot of opinions. If you want to do open track, i would suggest talking to the guys in your local club to see what to suggest. It is going to be a lot of trial and error. Definitely a rear sway bar (22mm maybe?). If you are going to do open track then I wouldn't buy anything less than tien SS. Which means JIC, TEin SS, Tein Flex, Springs w/konis, Tokico D-specs.
I am currently running JIC (450/500), neuspeed front strut bar, obx rear strut bar, rear poly LCA bushings, 19mm rear sway, and stock front sway (although I am probably going to go to the 15.9mm one). Don't forget to spend money on a good set of rims/tires and good set of brakes if you are going to be racing. upgrade your brake fluid and maybe even get SS brake lines.
Old Nov 22, 2004
yup ill be doing that later. and doesnt the progress adapter kit require welding?
Old Nov 22, 2004
Zzyzx's Avatar
Autocross Junky
Not that I know of, Just some drilling and a few brakets to bolt on... Grey did the swap, I think. Do a search, that should bring up every thing you need to konw about it.
Old Nov 22, 2004
plus im not sure how serious im going to get into it, i have an automatic (can u say lol?) but ive heard about this open track style of racing where they judge u on skill and not on time, so i want to see if theres anything like that around here. but yeah, ill just upgrade a few things and see how it feels, and if im not satisfied ill get deeper into it. oh, and what kind of springs would be good for a 1-1.5in drop with konis?
Old Nov 22, 2004
another question, lets say i want to just stiffen up the suspension, would i need springs or shocks or both? lets say not going all out for track racing, but just stiffening it for straight line acceleration to reduce weight transfer to the rear of the car.
Old Nov 22, 2004
Pn0ybOiLiKehOy's Avatar
Pn0ybOiLiKehOy is on a distinguished road
hotchkis sway bar...where do i get one of those?
Old Nov 22, 2004
robbclark1's Avatar
www.hotchkistuning.com
Old Nov 22, 2004
i dont see it on there..
Old Nov 23, 2004
Zzyzx's Avatar
Autocross Junky
they don't sell it seperatly.... you have to buy the RSX's street kit, which comes with a front and rear bar.
They do however sell their 27mm rear bar seperatly. :P
Old Nov 23, 2004
robbclark1's Avatar
Yeah but that says "FOR AUTOX/RACE USE ONLY!" 27mm rear bar!!
If you do decide to get the hotchkis bars, you may or may not be able to use the front bar. If you have an LX or DX you probably can use it, but you can't use it with a EX.
Old Nov 23, 2004
aw man i have an ex =/
Old Nov 23, 2004
Zzyzx's Avatar
Autocross Junky
you can still use the rear bar....
jordan1794
General 8th & 9th Gen
May 11, 2019 08:59 PM
Strycker
Aug 2, 2015 08:40 PM
17
Jul 23, 2015 11:48 PM
mrohitredd
Jul 21, 2015 09:26 AM
NoobyKid
Jul 13, 2015 07:53 AM
